No sleeper a/c ; (
Discussion in 'Peterbilt Forum' started by Rudy5, Sep 3, 2014.
  1. Rudy5
    Rudy5 Light Load Member
    54
    Mar 17, 2013
    My 1997 peterbilt 387 has good cab a/c but recently I began to try the sleeper a/c and not a link of cold, or hot for that matter, of air comes out. Like the blower is out or something. I looked at the fuse box relay and changed them out. Still nothing. Anyone got any ideas to what might be the problem with it? It's easy to hot in Phoenix to go without a/c.
  3. wes225
    wes225 Bobtail Member
    9
    Aug 2, 2014
    The only thing I can think of is freon. For now you are kind of screwed.
  4. Trygg
    Trygg Light Load Member
    221
    187
    Feb 11, 2014
    The West
    Take the Ice bucket challenge, you'll feel better. lol
    Rotorzilla Thanks this.
  5. Rudy5
    54
    Mar 17, 2013
    Freon? Nope, just had it charged up. Besides, the From can ac works fine. The sleeper won't even blow any air at all
  6. Rudy5
    54
    Mar 17, 2013
    Ice Bucket challenge? Ha, now that's funny.... Funny how? Like I amuse you? Hehehe.
  7. RSQ20
    RSQ20 Medium Load Member
    Find a DVOM and track down where the power to the A/C stops, repair defect, and chill...
    .... Philip
  8. skateboardman
    skateboardman Road Train Member
    6,232
    5,707
    Jan 14, 2012
    flatbed heaven
    sounds like the fan may be out , even if not cold it should blow,
  9. RebelYeller5
    RebelYeller5 Light Load Member
    68
    31
    Mar 11, 2012
    Birmingham AL
    Phoenix? Find a shady spot and just live with it. Maybe pretend you're in a sweat lodge, have a vision quest from heat stroke. Those crazy Phoenicians love that metaphysical crap.
  10. baha
    baha Road Train Member
    4,136
    2,837
    Jul 25, 2013
    ga
    Find a 12Volt test light turn on fan switch and unplug wire going to blower fan in bunk CK. if you have power at plug, if no go back to switch to be sure power is geting to fan switch? this way is cheaper that buying ever part till you find the one that is broken, fan switch, fan motor,wiring,
  11. Rudy5
    54
    Mar 17, 2013
    Thanx baha. After following through on what you said. Found the wires to the fan were corroded to the point that the ground wire was disconnected from the fan. Only a thread seemed to hold it together. Re wired it and it works fine now. Thanx again for all the replies
    baha Thanks this.
