no start Dd15 2010 freightliner cascadia
Discussion in 'Freightliner Forum' started by rshadle76, May 5, 2016.
  1. rshadle76
    rshadle76 Bobtail Member
    Here is my problem. You turn the key let the guages ddo there thing turn the key to the crank position and there is a 4-5 second delay before the starter will crank. And the motor will not fire.
  3. simon999
    simon999 Light Load Member
    240
    95
    Feb 6, 2014
    when turning start key, check with multimeter if you have 12v on the starter relay, solenoid, starter
  4. Animosus
    Animosus Heavy Load Member
    734
    2,916
    Dec 7, 2015
    SE Wyoming
    I doubt that's his problem since it will crank but won't start. I'd be checking codes if it won't fire.
    Step #1 for a crank no start condition is to check for fuel leaking out the bottom of your EGR hot pipe at the back of the EGR cooler. If you do get it started it could run away if there is fuel entering your intake. I'd say 70% of the time it's a stuck injector that causes a no start and dumps fuel in everything on the exhaust side.
