NO TAIL LIGHTS ON 2016 COTTRELL EZ LOADER
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by justcarhaulin, Feb 14, 2022.
  1. justcarhaulin
    justcarhaulin Light Load Member
    153
    238
    Jul 20, 2015
    Hallo drivers. Our ez loader trailer has no tail lights. Turn signals brake lights and side markers work. This is a very well taken care of trailer. I was planning on starting with the control box located on the tandems. I've checked and cleaned the pig tail connector. Where could the problem be? Stay safe out there.
  3. AModelCat
    164,761
    Start at the truck and make sure its sending power on that circuit. Then try and spread the tail light pin in the receptacle at the front of the trailer. If that doesn't work I'd just keep moving down the wire and check for power at every junction point until you lose power. If you get all the way to the lights themselves and still have power, check the ground for the tail lights.
    justcarhaulin Thanks this.
  4. Tropsnart
    Tropsnart Road Train Member
    1,130
    2,386
    Jun 8, 2015
    Pavilion New York
    Pull the taillights out of the box and check the wires. They'll often rub through and ground out your lights.
    justcarhaulin, Hammer166 and Old Man Thank this.
  5. Nobroker
    Nobroker Medium Load Member
    323
    310
    Jul 1, 2016
    Look for any hanging wires or harness under the trailer from the tail lights to the tandems
  6. kwswan
    kwswan Road Train Member
    2,028
    11,084
    Jul 26, 2009
    mcminnville,tn.
    Do you have marker lights down the side or is everything out? That would determine where to start looking.
  7. justcarhaulin
    153
    238
    Jul 20, 2015
    Thank you all for your help. I was able found what the problem was. The wiring harness to the tail lights lower level on the driver side are touching causing the lights to short out. I unplugged the female connector. All lights work except the one I unplugged. I Called cottrell to order a replacement but they are on back order. Cottrell is also having supply issues on parts.
    BigBob410 Thanks this.
  8. Banker
    Banker Road Train Member
    4,521
    14,682
    Aug 19, 2012
    Look on Raney’s.com for most all plugs for your lights or possibly a local chrome shop may have them since you can’t currently get them from Cottrell. Raney’s usually has them to you in a couple days. Generally they are a common plug and aren’t specific to Cottrell.
    justcarhaulin and BigBob410 Thank this.
