No trailer brake lights!!!!!!
Discussion in 'Freightliner Forum' started by Nazayar, May 28, 2014.
  1. Nazayar
    Nazayar Bobtail Member
    Hello can anyone help figure this tedious headache out???? I have lights to both units tractor and trailer but whenever I apply my brakes I get only the brake lights on the tractor but no trailer brake lights I have connected to several trailers and the issue is the same no trailer brake lights does anyone have a clue what this could be I have a new pigtail and a new connector which the pigtail connects to at the back of the tractor and still no brake lights on the trailer im at wits end with this one!!!
  3. generallee
    generallee Medium Load Member
    512
    441
    Jan 4, 2014
    Sounds like a bad wire going to the tractor connector. Figure out which pin it is and check it for power with someone applying the brakes to confirm or rule out.
  4. ipogsd
    ipogsd Heavy Load Member
    977
    515
    Jun 13, 2012
    Did you check fuses? Had same issue except lower parking lights.
  5. tucker
    tucker Road Train Member
    12,647
    40,425
    Jun 13, 2008
    IN
    Step 1, take a screwdriver and spread the prongs on your pigtail. Each end.
    Step 2, if that don't work, see Step 3
    Step 3, hopefully you don't need to see your trailer brake lights, to know that you're slowing down
  6. freightrunner
    freightrunner Heavy Load Member
    722
    182
    Mar 25, 2012
    Georgia
    I don't know why but my truck abs relay went out and caused the trailer brake lights to go out.
  7. jerseyguy71
    jerseyguy71 Light Load Member
    106
    52
    Jun 16, 2013
    plainfield,nj
    i'd check fuses & relays...fuses 1st:biggrin_25525:
  8. j.r.1981
    j.r.1981 Light Load Member
    113
    96
    Aug 22, 2012
    Check where your pigtale plugs into the tractor...had the same problem it was a broken pin on the tractor plug.
  9. back40
    back40 Light Load Member
    69
    18
    Feb 8, 2014
    The one thing I hate above all others electrical
  10. RSQ20
    RSQ20 Medium Load Member
    That is an indication of an incomplete ground...
    ....Philip
  11. rank
    rank Road Train Member
    9,919
    113,510
    Feb 11, 2010
    I had this with my '98 T800 a few weeks ago. After checking all fuses, pigtail and such, it turned out to be a bad trailer brake relay. It is located in the firewall, in the engine bay, on the driver side on T8.
