Noise Filter
Discussion in 'CB Radio Forum' started by TheSquatch, Jan 1, 2013.
  1. TheSquatch
    TheSquatch Light Load Member
    67
    6
    Aug 25, 2012
    Utah
    My radio sounds great but when I roll up the windows it squeals like a pig. Must be a bad ground some where.
    What do you guys recommend noise filter or not?
    If "Yes" will the $25 one at the truck stop be good?
    Any other recommendations?
    Thanks in advance. ^_^
  3. MsJamie
    MsJamie Road Train Member
    Turn down talkback?
  4. TheSquatch
    67
    6
    Aug 25, 2012
    Utah
    I have my talk back at about mid way always have. I tried adjusting it both ways and using the windows no effect.
  5. mike5511
    mike5511 Road Train Member
    3,157
    1,547
    May 15, 2011
    NW Arkansas
    I've watched the tech I use cure a squealing radio many times. Don't know what he does exactly, but it is more than turning down the talk back. But that is the first thing to try.
  6. cadillacdude1975
    cadillacdude1975 Road Train Member
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
    i have an on off switch for talkback on all my radios that have talkback. its kinda like that old tv informercial.......set it and forget it!
  7. TheSquatch
    67
    6
    Aug 25, 2012
    Utah
    I have the Galaxy 959 it has a push button for the talk back as well but that made no difference as well. No clear answer yet so if I install a Noise Filter this should clear it up right?
  8. cuzzin it
    cuzzin it Road Train Member
    3,647
    12,811
    Jan 19, 2008
    Berea, KY
    i had same prob. buying the noise filter did not help at all.
    TheSquatch Thanks this.
  9. handlebar
    handlebar Heavy Load Member
    I tried one of those, too, but I may have bought the wrong item from the infomercial. I had one of my CB rigs hooked up to The Clapper ("Clap on ... clap off!") and I ran off the road while trying to get the right radio turned on to get directions in downtown Charlotte..... :biggrin_25526:
    73 & Happy New Year, all.
  10. MsJamie
    I am at a loss as to how the window can cause a radio to "squeal". I can understand acoustic feedback from the talkback circuit getting into the microphone; the window gives a nice reflective surface for the sound waves.
    :mconfused:
    One thought... since you probably have passivated (metal containing) glass for your windows, the RF being radiated from all that excess coax winding around behind the dash no longer has a way to escape the inside of the cab, and it's getting into the audio amplifier of your CB.
    Seriously, though, try turning down the power (if you're running more than 4W) and see if the squeal goes away.
  11. cuzzin it
    3,647
    12,811
    Jan 19, 2008
    Berea, KY
    Power Window motor.... on the Volvo it was high pitch. on a Pete not so much
