Noise
Discussion in 'CB Radio Forum' started by sbaumann14, Sep 3, 2024.
  1. sbaumann14
    sbaumann14 Road Train Member
    1,236
    1,431
    Sep 1, 2010
    Rhinelander, WI
    Got an issue just driving me freakin nuts. When the truck is running, I can turn the squelch all the way down…gain all the way up, and I get a “swish swish swish” noise. Every 1/2 second. Only when truck is running. Moves the needle on meter.
    General Lee 5 yrs old from Bobs CB. Does it on my back up Cobra night watch also from Bob in 2001. 5’ Wilson tuned tip. 1.3 on ch 1, 1.6 on 40. Wilson gumdrop mount on a heavy duty mount on the metal mirror arm of my 03 FLD. 9’ of fresh Wilson coax.
    Mirror arms ground strapped to door, door to cab, cab to frame in 2 places. Stainless ground straps mounted with the paint etched off to give good contact.
    I even pulled out the 25’ jumper cables and ground to frame and also to battery and then started touching everything to make ground from frame, to door, to cab. No bueno.
    Have 10 gauge power cables coming off deep cells under bunk to cb. Grounded to frame. As it only does it when the truck is running, its getting electrical interference from somewhere but dam med if I can find it.
    Any ideas?
  3. 062
    062 Road Train Member
    6,329
    33,969
    Oct 20, 2013
    With the truck running unhook the coax at the radio. If it disappears screw the coax back in and unhook it at the antenna.
    Most likely the antenna is picking up the signal, but could be the coax.
  4. Ridgeline
    22,721
    123,342
    Are they GlenAir straps?
    Yes, there is a lot of places where coax can pick up interference.
    overall ... go here OP.
    Common mode current
    rabbiporkchop Thanks this.
  5. Lazer
    Lazer Road Train Member
    1,849
    2,981
    Jan 22, 2017
    Make, model, and year of truck?
  6. 062
    6,329
    33,969
    Oct 20, 2013
  7. sbaumann14
    1,236
    1,431
    Sep 1, 2010
    Rhinelander, WI
    Will try coax tomorrow
  8. Ridgeline
    22,721
    123,342
    Wonder what the OP found out.
    rabbiporkchop and Oxbow Thank this.
  9. sbaumann14
    1,236
    1,431
    Sep 1, 2010
    Rhinelander, WI
    Nothing yet. Got home…went camping. Going back to work Friday the 13th. Let ya know then.
  10. sbaumann14
    1,236
    1,431
    Sep 1, 2010
    Rhinelander, WI
    Am back to work. Will fiddle with it today and report what I find out
  11. sbaumann14
    1,236
    1,431
    Sep 1, 2010
    Rhinelander, WI
    FINALLY.
    I replaced coax…nope
    I bonded door, mirror, cab, EVERYTHING….zip
    Swapped out cb’s…nada
    New power wires…zero
    traced the noise to my power relay for my auxiliary batteries. I have a relay that feeds power to my auxiliary batteries when the motor is running so I can use em when I’m stopped for my laptop, bunk heater, ect. That’s where the noise is coming from. Had it grounded to the sleeper frame. Took the ground all the way to the main batteries….problem solved.
    What the hell…I needed new coax anyway. Lol
    handlebar, Timin770 and Concorde Thank this.
