Non Moving bolted 5th wheel?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by NJ LADYTRUCKER, May 11, 2017.
  1. NJ LADYTRUCKER
    NJ LADYTRUCKER Light Load Member
    78
    28
    Sep 22, 2013
    East Orange, NJ
    So here's my question. I have a 2011 Freightliner Cascadia and my 5th wheel is the type that is bolted down (non movable). I'm constantly overweight on my steers even with 1/4 tank and a light load. I need to get this fixed. Any suggestions for places that can fix this or possibly get one that slides and how much it would be to change it out?
  3. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    You would need to just buy a Fifth Wheel Frame with the Slider, you can reuse the same Fifth Wheel Top Plate.
    You would need to check what Make your Fifth Wheel is and contact a Distributor and get a quote on what one would cost.
    Most Freightliner trucks are equipped with Fontaine or Holland Fifth Wheels.
    You would also need to run a air line from the fifth wheel to a switch in the instrument panel.
    Most likely your truck already has the air line installed from the factory, so you would need to buy the Switch.
    I would estimate the cost with parts and labor could be around $1800 to $2500.
    Another less expensive option would be to purchase one from a salvage yard.
    Some fixed Fifth Wheels can be moved, but you will need to unbolt it and move it back towards the rear of the truck.
    heyns57 and NJ LADYTRUCKER Thank this.
  4. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    How much are you overweight?
    NJ LADYTRUCKER Thanks this.
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    I agree with everything boneebone said. I just want to emphasize to identify exactly what 5th wheel you have. Every brand makes several models, so knowing the brand might not be enough info to order the correct slider. Most 5th wheel manufacturers also make top plates for replacements for their competitors, this can add to the confusion if you do not know if it's original or not. This is why it's important to know the exact model/part #.
  6. Blackshack46
    Blackshack46 Road Train Member
    What are your axle weights in a scenario you described OP?
  7. AModelCat
    164,696
    Just unbolt it and slide it back. Any shop can do that.
    Its all just a matter of leverage. Once you find the sweet spot where you've maxed out your drives and steer at the same time, leave it alone.
  8. Pedigreed Bulldog
    7,737
    14,423
    May 7, 2011
    Exactly. Get your axle weights on a few different loads to give the shop an idea how far it needs to be moved. Once it is bolted down where it needs to be for proper weight distribution (should be 12K +/- 100# or so when the drives are @ 34K full of fuel), you shouldn't ever have to slide it...so there really isn't any need to spend a ton of money correcting an issue that could be solved in about 20 minutes for nothing but the labor.
    x1Heavy and NJ LADYTRUCKER Thank this.
  9. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    I believe that's called a stationary 5th wheel.If you're no more 500 lbs over the DOT won't say anything.Can't you just move the tandems to even the weight?Or tell the shipper to not load it all at the nose of trailer.
  10. NJ LADYTRUCKER
    78
    28
    Sep 22, 2013
    East Orange, NJ
    Always 1,000 pounds or more, even if my tank is empty! I've never had this issue except for when I bought this truvj!
  11. NJ LADYTRUCKER
    78
    28
    Sep 22, 2013
    East Orange, NJ
    **truck**
    I'm always anywhere from 13000-14000 on my steers. My drives and trailer are good.
