Northwest heavy flats
Discussion in 'Flatbed Trucking Forum' started by Roberts450, Jun 13, 2016.
  1. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Anybody here run northwest heavy spec flatbeds?? Looking at getting into it as an o/o and looking for some insite and maybe help with the truck and trailer specs.
  3. sliver
    sliver Light Load Member
    230
    242
    Feb 17, 2015
    idaho
    I have a set of a train flat beds but don't pull them all the time. Depends what your wanting if your wanting to pull 4 axle 53 ft with 4 axle truck wheelbase is important I know to get the full weight in Oregon I believe it is. Probably want 13 or 18spd 500 plus horsepower. That's what I'd want if I was gonna have a steady diet of it anyways.
  4. Roberts450
    2,237
    3,638
    Feb 6, 2016
    Yes Im looking at 53' 4axles and a 4 axle tractor 550/1850 to start with the big 18spd and big 40,000 rears with at least a 270wb. Just cant find much info here on heavy haul unless its RGN type work.
  5. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Your inner bridge is what will bite you in the ###. On the trailer you will want what they call an Idaho spread. My truck is a 254 inch wheelbase and I could scale 65000 pounds
    johndeere4020 and Ruthless Thank this.
  6. Ruthless
    Ruthless Road Train Member
    9,193
    91,314
    Aug 28, 2010
    The City.
  7. Ruthless
    9,193
    91,314
    Aug 28, 2010
    The City.
    And there you are lol
  8. cnsper
    5,869
    27,421
    Feb 28, 2014
    You also want a shallow Kingpin sitting on the trailer so you can get weight on the steer and still have the Bridge length
    johndeere4020 Thanks this.
  9. Roberts450
    2,237
    3,638
    Feb 6, 2016
    Cool thanks guys.
    I know I will need a big inner bridge as I run a setback axle truck now with a 244wb and a 150 inch lift to rear axle spread. We have so many different spec'd trailer that cant seem to get a straight answer on my bridge charts when going to a longer tractor wb to get to 105 from the 103 that we run. It also dosent help that pete is not offering setback axle gliders with the narrow cab anymore and Im also wanting a bigger sleeper over the 36"er Ive got and they wont install lifts under the sleeper. So far Im getting spec's of like 295"wb to get to 105 but like I said Im going crazybtrying it with our trailer spec's as I do bulk dry and wet tankers and will be switching to flats.
  10. cnsper
    5,869
    27,421
    Feb 28, 2014
    Here's a couple of things to shorten that wheelbase put the batteries between the frame rails and get dual 100 gallon tanks instead of 150 it probably have to fill up every day but you gotta stop anyhow
  11. cnsper
    5,869
    27,421
    Feb 28, 2014
    I can only carry about 170 gallons on my truck because this used to have a wet kit and half of the left tank is for hydraulic fluid
