Northwest Without jakes
Discussion in 'Experienced Truckers' Advice' started by Cummins525, Jul 31, 2019.
  1. Cummins525
    Cummins525 Bobtail Member
    9
    17
    Jul 4, 2013
    Hey all just looking for advise. Recently bought a 1986 KW K100E Cabover aerodyne with a 3406C catapillar and a 15 speed overdrive. The engine doesn't have jakes on it. I've been trying to get them put in but every time I order parts cat calls and says I need more. It's basically come down to I have to drive this truck due to other truck needing work. I run Kansas city to Portland and back every week pulling a 53 reefer. Looking for advise on the mountains with no jakes. I'm 28 years old but have been driving since I could reach the pedals. But I've never had a truck with no jakes. I've got a n14 currently and with jakes I still have to run down cabbage and others in low side 5th gear since none of the n14s I've had seem to have had strong jakes. I'm assuming the cat will be similar but have heard so many different stories on how to do this. My father has been doing this 40 years and said to just take it low gear and slow with light steady pressure on brakes letting the motor/Trans and brakes work together. He's made a couple rounds in the truck before me doing this and everything seems to have gone fine. Just curious on other experienced drivers in this area of driving. I like to research the crap out of everything before trying it myself. Sorry for the long post and thank you for any advise on this it's greatly appreciated.
  3. REO6205
    REO6205 Road Train Member
    13,168
    60,500
    Feb 15, 2014
    California.
    You've answered your own question. If your Dad did a couple of trips and everything went well, just listen to his advice and do it the way he did.
    Is it better to have jakes? Of course it is. Safer, too. But just take your time, use a little common sense, and you'll be alright.
  4. FoolsErrand
    FoolsErrand Road Train Member
    2,877
    12,169
    Sep 15, 2017
    Thats a scary thought. Id be tempted to mount a water tank and windshield washer pumps to spray the drums!
    mitmaks, 86scotty, FlaSwampRat and 3 others Thank this.
  5. bzinger
    bzinger Road Train Member
    16,657
    66,203
    Dec 10, 2014
    omaha , ne
    First truck I bought from dart was an 85 kw aerodyne k100 with a 310 cat derated to 285 with no Jake...I survived lol .
    Lepton1, andhe78, FlaSwampRat and 6 others Thank this.
  6. REO6205
    13,168
    60,500
    Feb 15, 2014
    California.
    You're in luck. We still have a couple of brake water tanks and some plumbing in our scrap pile. We'll let 'em go real cheap.
    We might even install them if you promise to let us come watch you use them. We're always up for some real entertainment.
  7. FoolsErrand
    2,877
    12,169
    Sep 15, 2017
    Well, ive been known to put on a show.
  8. REO6205
    13,168
    60,500
    Feb 15, 2014
    California.
    Do you want the water tanks or were you just trying to throw a scare into the OP?
    Sounds to me like he has his act together pretty well and smart-### comments from people with nothing valuable to contribute probably won't do him much good
    just_sayin, AModelCat, Lepton1 and 4 others Thank this.
  9. D.Tibbitt
    157,286
    If u have a air pressure application gauge on ur truck . hold it at 10psi and that is enough brake pressure to hold u , and still light enough for the break drums to be able to spread the heat across the drums without smoking.provided u are in the right gear. If u need anymore pressure than that then drop a gear and try again.
    ChevyCam, snowwy, just_sayin and 6 others Thank this.
  10. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Not hard to put Jake's on that engine. Plenty of them had Jake's. Phone around to the salvage yards. Jake heads , pedestals, bolts and valve cover spacers.
    Why run it without.
    just_sayin, Lepton1, Bean Jr. and 3 others Thank this.
  11. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I agree with this. You can perty much go down any hill with a steady 10psi application and not smoke the brakes. If you need more then that your going to fast. And for God sake dont be one them guys that fan the brakes , contrary to what they say , this will get you in trouble. Slow and steady gets it done.
