Not allowed to buy DEF
Discussion in 'Experienced Truckers' Advice' started by Criminey Jade, Feb 11, 2015.
  1. Criminey Jade
    Criminey Jade Road Train Member
    1,609
    1,803
    Aug 16, 2013
    Not Colorado Anymore
    Here's a goofy one for you. I am presently temping with a P&D/LTL firm. I noted on two days worth of pre-trips for the same truck that the DEF level is low. The shop had no DEF so I bought some when I fueled yesterday. Today, I was told I am not allowed to fill the DEF tank. Okay, so if you're letting the DEF run down, how are you keeping the engine from derating? Surely that doesn't apply to just Freightliners.
  3. 25(2)+2
    18,759
    45,987
    Sep 18, 2006
    the road less travelled
    We have bulk DEF at the shop, although the mechanics have to fill it(well, they are supposed to fill it so I don't bother to do it anymore).
    We can purchase if needed with the EFS card. They'd rather we didn't because the shop gets it at lower cost.
  4. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    Just let it run out.
    They will let you buy DEF from that day on. (or next day).
    JReding, dca and Infosaur Thank this.
  5. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    Maybe there is another way to get the company to fill the def tank, like a list in the shop or something. Good chance nobody is reading your pre trips. You might have to fill it yourself at the terminal.
    A Bug Thanks this.
  6. A Bug
    A Bug Heavy Load Member
    960
    1,984
    Mar 15, 2014
    Sevierville TN
    That just sounds strange not being able to fill your own def tank.
    I hardly see the maintenance shop more than once a month.
  7. Mountain Hummingbird
    Mountain Hummingbird Medium Load Member
    601
    399
    Oct 14, 2012
    Just keep noting it on your pres they will learn the hard way when it runs out.
  8. Vilhiem
    Vilhiem Road Train Member
    3,992
    10,904
    Oct 6, 2014
    Might be because the repair bills for when someone crosses tanks between def and diesel added up too quickly...
    Better off teaching the right way to do it over delegating responsibilities.
  9. UKJ
    UKJ Heavy Load Member
    781
    576
    Dec 28, 2014
    On any non-cdl truck i've used DEF is a blue cap, diesel is green, e85 is yellow not really easy to mix that up, how is it even possible to mix those up? Is the color scheme somehow different on a class 8?
  10. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    In a large enough sample size, you will get some very unintelligent few. When these systems first came out , several trucks the DEF tank got filled with window washer fluid. ( on most cars its a blue cap under the hood). Many have been fill with diesel ( not sure how they got the handle in) . But stupid stuff happens.
  11. sdaniel
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Jade you have a rough time at every turn? Hope you have better luck from here on out!
