Not CARB Compliant?
Discussion in 'Trucking Industry Regulations' started by LeadbyExample, Mar 24, 2014.
  1. LeadbyExample
    LeadbyExample Bobtail Member
    11
    Any thoughts on how a 2008 trailer with a 2008 TK unit & engine would not be CARB compliant currently? I'm posting this thread because I've run into a situation where a fleet selling off one of its trailers is telling me it's not CARB compliant.
    Appreciate it.
  3. Dryver
    Dryver Road Train Member
    2,818
    2,576
    Nov 30, 2008
    Sioux Falls, SD
    2008 model reefers have until the end of 2015 and can run after that with modification. Maybe this TK unit has older stuff in it, older engine?
  4. LeadbyExample
    11
    Thanks Dryver.
    I'm awaiting an answer to that. I'd like to know if the engine has been rebuilt or replaced?
  5. Studebaker Hawk
    Studebaker Hawk Road Train Member
    3,021
    9,859
    Oct 18, 2010
    NW Indiana
    Model year of either vehicle is not the determining factor. It is the EPA year the engine and engine family that you have to go by. A vehicle might be titled as a 2008 but has a 2007 engine with no DPF filter, hence not compliant.
    281ric Thanks this.
  6. LeadbyExample
    11
    Studebaker, it is a 2008 TK unit with a 2008 TK engine (which I verified thru TK per the s/n). Furthermore, the EPA sticker states a 2008 MY engine.
    So all check-points indicate to me it's a CARB compliant unit.
  7. northstarfire0693
    northstarfire0693 Heavy Load Member
    865
    598
    Jul 1, 2006
    NC
    Ok I know their have been many changes since I have been off the road, but would the trailer only need to be CARB compliant if you were running CA ? I dont see where the big deal would be if you stayed out of CA
  8. LeadbyExample
    11
    Northstarfire, I do run loads in & out of CA, so my equipment would need to be CARB compliant.
  9. wichris
    wichris Road Train Member
    4,512
    9,293
    Jan 17, 2011
    Go online and register it. If it is a 2008 motor it will be compliant through 2015. Doesn't cost anything to register the TRU.
  10. ITS62
    ITS62 Light Load Member
    164
    69
    Apr 29, 2011
    Gilroy, CA
    Only 2010 or newer engines are truly CARB compliant. A 2008 IS currently CARB compliant by a 2008 only buys you some more time before you need to modify or dump.
  11. wichris
    4,512
    9,293
    Jan 17, 2011
    OP was asking about a TRU, not a tractor.
