Not much heat in c15
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Perchie15, Feb 7, 2023.
  1. Perchie15
    Perchie15 Light Load Member
    253
    75
    Aug 16, 2021
    How come I don’t have much heat on my truck? I have winter front on! And belly tarp when it’s -30 windows go frosty and need to use my Amex card to scrap the window from the inside!! It’s a Westernstar and when I put it in full defrost. There is still decent air flow coming out of the face vents…
  3. Lazer
    Lazer Road Train Member
    1,850
    2,983
    Jan 22, 2017
    It’s possible the heater core is plugged. Check if the truck has water valves on one, or both of the heater hoses, make sure they are fully open.
    Diesel Dave Thanks this.
  4. Perchie15
    253
    75
    Aug 16, 2021
    Difference in temperature is like 8 degrees from in to out of the core! But why can’t I get heat to defrost also? It stays on vent
  5. Magoo1968
    Magoo1968 Road Train Member
    2,062
    5,493
    Mar 18, 2021
    St Malo mb
    What’s your water temperature
  6. Perchie15
    253
    75
    Aug 16, 2021
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I had a 2013 that also sucked in the winter.
    Eventually I found that the cab heat control cable was mounted too far up the lever on the valve before the heater core. When it was dialed as fully open, the core of the valve only had about an 1/8” of an opening.
    I repositioned the cable lower down on the arm of the valve , this gave the control dial in the cab the ability to rotate the valve further, so it fully opened.
    I was nice an toasty after that.
    Magoo1968 Thanks this.
  8. Perchie15
    253
    75
    Aug 16, 2021
    Well I found a space that there’s like 3Ts in the coolant lines. So that could be part of the issue.
  9. Lazer
    1,850
    2,983
    Jan 22, 2017
    Just to clarify, is hot air coming out of the dash and floor vents? But not coming out of the defroster vents?
  10. Perchie15
    253
    75
    Aug 16, 2021
    Yeah when it’s on defrost it’s only coming out of the vents. Don’t get hardly any air out of defrost! I flip it back and fourth to defrost and vent. Airflow doesn’t seem to change. I see the lever switch move in behind that cluster move when I go from defrost to vent then I see a airline but no air leaking
  11. bad-luck
    bad-luck Road Train Member
    3,449
    6,359
    Nov 16, 2013
    Baltimore, Maryland
    May be the actuator for the blend door, it is not opening all the way.
