Nox conversion low/def quality
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Pendulum, Mar 6, 2018.
  1. Cattleman84
    Cattleman84 Road Train Member
    10,021
    71,551
    Nov 1, 2017
    The Sticks, Idaho
    I had a very similar issue with a 2016 Volvo... But when it threw that poor quality Def code it also began a count down to derate me... I got pulled into a rest area about 2 miles down the road and did a parked regen... That fixed the code and derate issue... For the time being at least. And that particular regen took over 90 mins to complete!
  3. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    @Two wolfs what year is your truck ? as far as I know since 2011 def pumps don't have bladder.
  4. Two wolfs
    Two wolfs Bobtail Member
    9
    Jun 29, 2018
    It’s a 2014 cascadia.
    I didn’t know about it either but that’s what they said was broken last time I went. New pump as well.
    And I did a parked regen as well every time I get the code and flashing def, but it would always come back.
    mhyn Thanks this.
  5. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    BIG THANK YOU FOR THIS INFO !
    I have a truck with similar to yours 4364/18 issue. All tests are done and passed. I have big doubt that 1-box is toasted. I will check bladder pressure tomorrow.
    Pendulum Thanks this.
  6. Verdel
    Verdel Medium Load Member
    599
    135
    Oct 26, 2013
    Do you miss your Century now? :)
  7. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    oh yes. Both my Centuries were good trucks. Real moneymakers.
  8. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    Back to Low Nox BS. I just checked the bladder pressure and it was 0. When I saw that valve I said thank you Germans that you have used regular schrader valve here and not something fancy that would require special tool. I have put 46psi into bladder and now will test it. I will be back in 2-3 days with results.
    Two wolfs Thanks this.
  9. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    What a beautiful place is this forum. Every day you learn something. Thanks that person who created this forum.
    SAR and Two wolfs Thank this.
  10. Goods carrier inc
    Goods carrier inc Bobtail Member
    16
    8
    Feb 4, 2020
    ON 2012 CASCADIA IT TOOK AROUND 6 MONTHS TO BAD OUTLET SENSOR CODE POP ON DASH . MAY BE ITS NOT FAILING COMPLETELY OR WHEM IT FAIL IT SUSPECT ON UR DEF QUALITY FIRST ......EVERTHING STARTED WITH BAD QUALITY AND LOW COVERSION AND CHANGING PARTS .SOME SAYS I NEED ONE BOX I FLUSH MY TANK AND FILLED WITH BOX DEF FLUID AND MY BAD QULITY GONE BUT LOW CONVERSION STILL THERE AND I DRIVE 6 MONTHS WITH LOW CONVERSION CODE ONLY ...IN BETWEEN I TRIED 3 TIMES TO FILL BULK DEF FROM PUMPS AND BAD QUALITY POPS EVERTIME .THEN FLUSH BACK AND PUT BOX FLUID IN .
    AFTER DRIVIING 3 MONTHS ON BOX FLUID BAD OUTLET NOX SENSOR CODES POP UP AND I CHANGE .ALL IS GOOD AFTER THAT DRIVING SINCE 4 MONTHS...ON BULK DEF FLUID..
