O/O oldschool question
Discussion in 'Ask An Owner Operator' started by timmytorco, Jun 10, 2016.
  1. timmytorco
    timmytorco Bobtail Member
    17
    10
    Jun 10, 2016
    Looking at an 85 K100 cabover with a 400 Cummins. Is this a feasible otr truck if I don't haul super b's and don't haul mountains? I haul a deck and usually around 60k pounds. Calgary is as far west as I usually go. Haul Midwest us a fair bit.
    Thanks.
  3. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    Great truck, but competing without an electronic controlled engine will cost fuel. Right now fuel is cheap, but when it goes up again the difference will be more noticeable. Also on an older truck usually the tires will need replacing and oil and wheel seals will leak resulting in needed repairs and delays.
    timmytorco Thanks this.
  4. timmytorco
    17
    10
    Jun 10, 2016
    For what the truck is worth, I can afford to spend some money to get it road ready. It has new virgin tires all around. I plan to spend some time getting it ready before it hits the road. Was just concerned about a la k of power. I refuse to look at anything newer than 05 with emissions.
  5. mnmover
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    The truck will not have a charge air cooler.
  6. timmytorco
    17
    10
    Jun 10, 2016
    It's a pretty common swap the to go from h20 to air to air isn't it?
    OLDSKOOLERnWV Thanks this.
  7. shovel98
    shovel98 Light Load Member
    251
    241
    Jan 15, 2011
    mn
    Look close at the cross members the aluminum brackets tend to break from corrosion underneath them. Don't see where lack of power would be any issue I pulled a lot grades with a b model cat at 310 hp and never had to be pulled up a grade. Heck even ran a L10 cummins coast to coast isn't going to win any races but got the job done. Just remember you dont run a older cummins like these new ones you will score a liner if you do.
  8. rocknroll81
    rocknroll81 Road Train Member
    1,363
    1,005
    Sep 29, 2010
    West Allis Wi.
    I used to haul 45-48,000 beer loads back in the late 80's, had a Pete 362 with a NTC 350 Cummins and had no issues at all.
    OLDSKOOLERnWV and timmytorco Thank this.
  9. azheavyduty
    azheavyduty Medium Load Member
    340
    1,089
    Jan 11, 2011
    Glendale, AZ
    Remember when 400BC was big power?
  10. timmytorco
    17
    10
    Jun 10, 2016
    Nope. I'm an old trucker trapped in a young truckers body.
  11. Fatboy42
    Fatboy42 Light Load Member
    281
    389
    Feb 9, 2011
    Indiana
    I run the truck in avatar 77 352 350 big cam 10 sped 3.90 no issues go for it.
