O/O Power only help/advice
Discussion in 'Ask An Owner Operator' started by MadX, Sep 8, 2020.
  1. MadX
    MadX Bobtail Member
    9
    Sep 8, 2020
    I have but there's hardly ever rates
  3. MadX
    MadX Bobtail Member
    9
    Sep 8, 2020
    Good to know. This is why I'm asking questions now before I give up the day job
    kimbosa Thanks this.
  4. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    Look at Schneider, Werner and Landstar Broker, they have power only loads, as does Prime INC, and at Prime you get to use their fuel card for discounts. New trailers always being shipped from UT and VA and AR, just watch the load boards, but sometimes new trailers do not pay a lot. A heavy duty pintle hook can come in handy on power only at times.
    MadX Thanks this.
  5. danny23tx
    danny23tx Road Train Member
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    JBH might be a option for you , PM coming your way .
    MadX Thanks this.
  6. loudtom
    loudtom Road Train Member
    1,717
    2,806
    Aug 26, 2016
    Power only is typically cheap, and it usually takes a bit to find the freight that pays well. If you want to diversify, you'll want a winch bar for tightening straps for flatbed loads. You might want extra straps as well, in case they don't have them or their straps are damaged. Sometimes there are oversize power only moves, so you'll want all the flags and signage required, as well as knowing your routes and permits. Another load that pops up periodically are pintle hitch moves. If you have a receiver that you can swap from pintle to ball, as well as properly converting your wiring for lights, you can haul travel trailers and boats. Some customers have lift gates, which might require additional wiring to power it.
    It's a lot of effort, and usually the good paying freight is not consistent enough. Plus the cost of non-owned/trailer interchange is usually more than just insuring your own trailer. There can be times the trailer has no registration, plates, or DOT inspection. There could be times where the trailer needs to be worked on before it can safely move. I've even had a load out trailer advertised as a 53' with swing doors, and end up being a 48' with roll doors, making it harder to find freight. People are customizing trailers with flanges and attachments that put it over the legal dimensions, and expecting you to haul it without a permit or pay out of your pocket.
    I've made more money with a trailer than doing power only.
    Dino soar, MadX and kimbosa Thank this.
  7. kimbosa
    kimbosa Medium Load Member
    524
    351
    Jul 4, 2011
    lufkin texas
    i here ya! i thought i new a lot about trucking but these guys and ladies know there stuff. this has been my collage on trucking. good luck brother trucker
    MadX Thanks this.
  8. bad-luck
    bad-luck Road Train Member
    3,449
    6,359
    Nov 16, 2013
    Baltimore, Maryland
    It really depends what you want to haul. I would recommend starting out in a dry van, as there is plenty of dry van work
    Midwest Trucker and MadX Thank this.
  9. MadX
    MadX Bobtail Member
    9
    Sep 8, 2020
    I think dry van would probably be ideal for me to start with the more i think about it. Is there anything to look for when it comes to renting a trailer? I know there's a local outfit that does rent dry vans and i know they are reputable.
    Also, thanks everyone for the input so far. This has been very helpful
  10. Midwest Trucker
    5,914
    21,390
    Aug 31, 2018
    Power only is a tough deal.
    I never understood why people don’t just spend 15 to 20k on a nice, mostly maintenance free trailer and make far more money.
  11. MadX
    MadX Bobtail Member
    9
    Sep 8, 2020
    I am just nervous about overextending myself as well. I have a decent amount of money ready for this journey but I'm still nervous about having payments on equipment. I will be trying to avoid that as much as possible but i'm sure i will be making plenty of mistakes as i start out so I want to have as much liquid cash for emergencies as i can. I can fix a lot of things myself if the tools i have can do it but i am not a diesel engine mechanic.
