O/O Power only help/advice
Discussion in 'Ask An Owner Operator' started by MadX, Sep 8, 2020.
  1. Cat sdp
    Cat sdp . .
    21,320
    76,354
    Apr 8, 2012
    Orion's Belt
    Trailers are cheap compared to trucks........and no emissions systems (unless it’s a Reefer)
    OldeSkool and Midwest Trucker Thank this.
  3. Midwest Trucker
    5,914
    21,390
    Aug 31, 2018
    Trailers make you money. And depreciate very little. If you can’t afford to buy then rent for a few years from a place like Xtra. Do not however jump into a lease or you might as well be buying.
  4. bad-luck
    bad-luck Road Train Member
    3,453
    6,367
    Nov 16, 2013
    Baltimore, Maryland
    When renting, look for a flat rate only. Not a rental with a flat rate and mileage. Generally the rental covers all maintenance including tires, unless you damage a sidewall. Its important to do a walk around with the sales rep and note any damage.
    MadX and OldeSkool Thank this.
  5. OldeSkool
    OldeSkool Road Train Member
    2,076
    6,708
    Jul 17, 2018
    New Hampshire
    The last two posts about leasing a trailer are very good. Go back and re read them. ;)
    MadX Thanks this.
