Occassional problem-Reefer won't begin cooling again after defrost?
Discussion in 'Refrigerated Trucking Forum' started by loose_leafs, Feb 27, 2015.
  1. loose_leafs
    loose_leafs Road Train Member
    Jan 3, 2014
    1,294
    Thanks Received:
    1,468
    Old Man River, MN
    We have about 10 2013 Carrier reefers in our fleet, they are either X4 7300 or 7500. Every once in a while they will do this:
    After a defrost cycle, the unit will not cool at all, ie, you go into the sensors for supply air temp and it will not even begin producing cold air. Its as if its just recycling whatever is in the box. Engine will keep running until it throws a code for either "computer error" or "microprocessor error", I don't remember which. But after a certain amount of time it will shut down and throw that code, sometimes along with "box temp out of range".
    I'm not sure if the code has ever cleared on its own and restarted, but I know if I catch it and shut the whole unit off for a few minutes, let everything clear, and restart, it will work just fine like nothing ever happened. Anyone ever encounter this problem?
    I am thinking that maybe a solenoid or valve somewhere is sticking, because the unit doesn't ice up, it simply produces no cold air until you shut it off and restart it.
    KB3MMX Thanks this.
  2. laverty
    laverty Bobtail Member
    Nov 30, 2009
    14
    Thanks Received:
    MI
    Older ones tend to go brain dead and that is the fix. Just shut her off for ten seconds and restart. Good to go...
    KB3MMX Thanks this.
  3. loose_leafs
    Jan 3, 2014
    1,294
    Thanks Received:
    1,468
    Old Man River, MN
    Older? They are barely two years old
    KB3MMX Thanks this.
  4. wichris
    wichris Road Train Member
    Jan 17, 2011
    4,276
    Thanks Received:
    8,603
    If they all do it then it could be a software issue. What does carrier say?
    KB3MMX Thanks this.
  5. Johnny holt
    Johnny holt Bobtail Member
    Aug 4, 2015
    19
    Thanks Received:
    7
    Sounds like its freezing up, try manual defrost see if that works!
  6. loose_leafs
    Jan 3, 2014
    1,294
    Thanks Received:
    1,468
    Old Man River, MN
    Its not icing up, I said it does this after it finishes the defrost cycle. It simply won't start to cool again. Shut the unit, restart it, it will run just fine.
    KB3MMX Thanks this.
  7. loose_leafs
    Jan 3, 2014
    1,294
    Thanks Received:
    1,468
    Old Man River, MN
    Carrier shops are beginning to become nearly as incompetent as the new breed of truck drivers. Rather than actually pinpoint and fix the problem, they would rather try their luck at replacing major components like compressors. Occasionally, there are a few good ol boys at a carrier Thermo King shop that know their stuff. But that is very rare today
    KB3MMX Thanks this.
  8. Matt Ross
    Matt Ross Bobtail Member
    Aug 15, 2015
    Thanks Received:
    I have a 2015 X4 7300 and its a big pos. if the temp outside reaches 100 degrees or more. The unit shuts off. I've been to 4 carrier dealers even the one in Phoenix and they all tell me it's a software problem and carrier headquarters is working on it but as of right now they have no fix for it
    KB3MMX Thanks this.
  9. loose_leafs
    Jan 3, 2014
    1,294
    Thanks Received:
    1,468
    Old Man River, MN
    The ones we got 2 years ago would not shut off in colder weather if you left them on stop/start. Not sure if carrier ever fixed that issue either, but any time the temp outside got below about 15 degrees...the command to #### off the unit when it reached the setpoint would not go through because the engone coola temp was not warm enough. That may be a good thing to keep the fuel from waxing and gelling, but overall that wastes a lot of fuel if the weather stays above 0 degrees.
    KB3MMX Thanks this.
  10. Rick Brown
    Rick Brown Light Load Member
    Jul 16, 2011
    255
    Thanks Received:
    415
    Monroe NC
    When all else fails, reboot.
    KB3MMX Thanks this.
