Odd Dual Antenna Setup
Discussion in 'CB Radio Forum' started by TheSquatch, Dec 10, 2012.
  1. TheSquatch
    TheSquatch Light Load Member
    67
    6
    Aug 25, 2012
    Utah
    Im running a 2010 International full size cab/sleeper. I have a Galaxy DX 959 and dual antennas the antenna on the drivers side is the K40 20,000w and the one on the passenger side looks like a basic 100w. I dont have the money to buy a second K40 yet so I started with 1. My question is, will this couse any problems? My SWR is literally at 1 on all channels hardly moves at all and incomming transmitions are crystal clear.
  3. MsJamie
    MsJamie Road Train Member
    If it ain't broke, don't fix it.
    I can't see why having different antennas would make any difference. May skew the radiation pattern a bit, but going around a corner would skew it a lot more...
  4. Powder Joints
    8,030
    8,489
    Sep 25, 2007
    Rosamond, SoCal
    Which ever one has the longest whip is probably the dominate antenna. There both 50 ohm antennas so by theroy you can do this. I would not but it ok for you. I would run a single antenna till I picked up the other matching. Personally I think K40 are way over rated.
  5. TheSquatch
    67
    6
    Aug 25, 2012
    Utah
    I didnt think it would but im a newb to CB's and would hate to brake somethink. :biggrin_25524:
    I would assume the crappy antenna would just do the crappy job it does wail the K40 would do much better. Whats why I placed the K40 on the drivers side.
  6. TheSquatch
    67
    6
    Aug 25, 2012
    Utah
    Only problem is both cables are spliced into the same end piece.
  7. MsJamie
    Only if you replace the coax as well. Removing one antenna but still running the dual harness will do Bad Things to your radio.
    TheSquatch Thanks this.
  8. M818
    M818 Light Load Member
    286
    147
    Apr 27, 2011
    Dallas, Texas
    That wire is not 50 ohms IIRC it is 75 Ohms on a "co-phase" setup like that. right or wrong?
  9. MsJamie
    While there are multiple ways of impedance matching two 50Ω antennas together, using two quarter wavelengths of 75Ω cable is the most common.
    The problem is that an unterminated 1/4 wavelength piece of coax acts like a dead short at that frequency...
