odd question. my coolant over flow never gets any fluid in it.
Discussion in 'Volvo Forum' started by damil, Oct 3, 2016.
  1. damil
    damil Light Load Member
    171
    248
    Sep 23, 2012
    I have a o7 vnl with a d12. I have had it for two years and it has never gotten any type of coolant in the drivers side of the plastic fill area that I am assuming is a over flow. recently I was pulling a hill in Colorado and ran a little warm and it still stayed bone dry. it has hoses hooked up to it. is this normal?
  3. Mudman78
    Mudman78 Light Load Member
    106
    108
    May 23, 2016
    Yes. It's there to capture overflow in an overheat situation. If your truck is running normal, it will never have coolant on the driver's side of the tank.
    silver dollar and damil Thank this.
  4. nasriza
    nasriza Road Train Member
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    Mudman78 Is right the only reason you are going to have any coolant in the driver side is excessive overhear or the other way is if there is excessive pressure in the cooling system at which point it will fill it up and start pissing it out of the overflow it's never good news to have coolant on the driver side so your truck is just fine
  5. Scarface II
    Scarface II Bobtail Member
    5
    I had the same issue of overflow.. specially after running for a while the coolant drains through overflow pipe and there is coolant on the driver side of the reservoir.. Engine doesn't get overheat, even in hills..
    Any Solution to this please ::
  6. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Nothing will overflow if your low on coolant in the radiator. You need to fill the radiator first. Probably why your running warm. You can't fill your radiator from the overflow tank once it's low
    Scarface II Thanks this.
  7. Mudman78
    106
    108
    May 23, 2016
    Coolant will go to the driver's side of the tank for two reasons:
    1) Overheat
    2) Bad air compressor head gasket causing the air compressor to overpressurize the cooling system.
  8. Scarface II
    5
    Thanx Mudman78 ..
    Any idea 'How much will the repair cost'
  9. Mudman78
    106
    108
    May 23, 2016
    Couldn't say. Our trucks are 9 years old and have anywhere from 500,000 to 700,000 miles. We have 50 of them. It's to the point that it's not worth doing just the head gaskets (even though it can be done). We replace the whole compressor. I would suggest a proper diagnosis before just slapping a compressor in it.
  10. Scarface II
    5
    Will do that ... Mudman78
    Thanks..
  11. Scarface II
    5
    I replaced the cap.. It fixed the problem
