Oh well, I'm down D16 spun a bearing
Discussion in 'Volvo Forum' started by sbreeden, Jun 18, 2020.
  1. sbreeden
    sbreeden Light Load Member
    73
    55
    Dec 15, 2016
    Lost my engine due to a spun bearing, ate into the block. At least it lasted to deliver my cargo and get me home. Dealer opening the bottom and saw all the metal in the pan, removed the bearing and was dead at #4 cylinder, to far gone to rebuild. The crankshaft was damaged also. Engine lasted 1.3 million miles with no overhaul.
    A reman engine at a tune of $47k, found a full dress used one with so called 360k on the clock for $12k, with 30 day warranty, should be at the dealer on Tuesday, they charging $9k to install. Before installed they going to check the upper and lower and pressure test it. Hopefully I can get 1 million plus out of this one.
  3. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Any warning before she spun? Do you monitor the oil pressure?
  4. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    How far did you drive it with a spun bearing? I only ask because I'm guessing it made a heck of a racket and shook.
    Coffey and Rideandrepair Thank this.
  5. tommymonza
    tommymonza Road Train Member
    4,519
    12,851
    Sep 10, 2013
    S.W. Florida
    9 thousand dollars to swap out dressed motors.
    That Sounds perfectly Reasonable .
    Rideandrepair, sealevel and Ffx95 Thank this.
  6. Frontman
    Frontman Light Load Member
    166
    151
    Apr 4, 2012
    What engine?
    Rideandrepair Thanks this.
  7. Ffx95
    Ffx95 Road Train Member
    1,370
    2,636
    May 18, 2017
    9 grand to swap motors? WTH
  8. MACK E-6
    50,481
    243,065
    Volvo D16...
    Rideandrepair, Doealex and Frontman Thank this.
  9. Frontman
    166
    151
    Apr 4, 2012
    Dang! Don't know how I missed that.
  10. bad-luck
    bad-luck Road Train Member
    3,509
    6,506
    Nov 16, 2013
    Baltimore, Maryland
    That sucks, sorry to hear that. Did you ever have the rods and mains done? Once you spin a bearing, the block is done. I have mine done at 500k
  11. bad-luck
    3,509
    6,506
    Nov 16, 2013
    Baltimore, Maryland
    Fyi a bearing spins when the bearings are worn out, and haven't been changed. Doing rods and mains prevents this
