Oil capacity? DD60 14.0 515HP?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Rowdy Finn, May 21, 2012.
  1. Rowdy Finn
    Rowdy Finn Bobtail Member
    44
    4
    Oct 7, 2010
    Eastern NC
    Bought a new/used FRTLNR 05. Love it! Engine sticker says 515 HP @ 1800 rpm. Is it a 515? I want to do an oil change before I take it out for the first time. Where do I find oil capacity listed? Looked in manuals that came with it and don't see it anywhere?
  3. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    Don't quote me, but I believe the capacity is 36 quarts, not sure if that includes the oil filter. If its 515, your tach should go to 2,100. If its 455, then 1,800. This is usually how they are programmed.
  4. Rowdy Finn
    44
    4
    Oct 7, 2010
    Eastern NC
    Sticker on engine says, 515 HP @ 1800 RPM. Sticker behind removable dash-panel on passenger side says 455 HP. Kind of cryptic. Guess it doesn't matter too much as it's a single-axle that's hooked to a 3-car flatbed trailer. Hopefully will take the hills OK either way.
  5. freightlinerman
    1,287
    536
    Mar 4, 2011
    Florida
    It's only 455 then. If you're max RPM is 1,800 its 455, 515 has 2,100 RPM's. Some times with cruise on your HP will be higher.
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    i'm not sure, 35 lit. as I remember, may be 36-38
  7. Crusty
    Crusty <b>Just Plain Crusty</b>
    345
    140
    May 29, 2010
    Canton, GA
    Just Google it. I can usually pdf manual on just about anything. Just try phrasing it in different ways.
