oil change intervals
Discussion in 'Questions To Truckers From The General Public' started by bigrigspartan, Mar 30, 2011.
  1. bigrigspartan
    bigrigspartan Bobtail Member
    detroit, michigan
    onhighway versus offhighway construction. What oil change intervals do you recommend?
  3. Allow Me.
    10,814
    12,792
    May 28, 2009
    Rancho Mirage, Ca.
    Ask 10 drivers, you'll get 10 answers. In dusty conditions, I would do about monthly or 7500 miles. On road, 15-20,000 miles. However, most oil manufacturers are claiming 30,000 and up and most truck companies are stretching their changes to 30-40,000. Some will change just the oil filter at about 20,000. But, lets face it, clean oil extends engine life.
  4. bigrigspartan
    detroit, michigan
  5. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    off highway I change mine at 250 hrs
    bigrigspartan Thanks this.
  6. Licensed to kill
    Licensed to kill Heavy Load Member
    830
    2,435
    Dec 31, 2010
    Alberta
    250 hrs in summer, 500 hours in winter.
  7. paul 1052
    paul 1052 Heavy Load Member
    899
    346
    Oct 9, 2010
    Sand Springs, Ok.
    Sample the oil and change it when the lab says it's bad.
  8. SmokeyCowboy009
    SmokeyCowboy009 Heavy Load Member
    715
    315
    Mar 4, 2009
    Watertown, WI
    25k mi. should be the max.
    just remember it can get expensive to change every month.
    if you can make one every quarter that should do it.
  9. qwiktruck
    qwiktruck Bobtail Member
    7
    Sep 21, 2011
    New York, NY
    Just out of curiosity, what is the biggest cost of a big-rig oil-change? Is it the oil itself, the parts (drain valve, oil filter, etc), the labor, or the time off the road?
    I see a lot of variation from 25k to 45k here, and am wondering where the reason for the difference is. Thanks.
  10. dirtyrabbit
    dirtyrabbit Medium Load Member
    415
    158
    Jun 19, 2011
    KS
    Company's new KW's are set to have the first one at 40K. Previously the shop did them every 35K.
  11. crzyjarmans
    crzyjarmans Road Train Member
    3,367
    2,542
    Jun 9, 2010
    Home
    when i did heavy haul, drove a company truck, they wanted every 10,000 miles, as an otr, in my own truck, I do 15,000,(not heavy haul)
