Oil Consumption C-15
Discussion in 'Ask An Owner Operator' started by colorado18spd, Apr 3, 2015.
  1. colorado18spd
    colorado18spd Medium Load Member
    396
    298
    Mar 10, 2013
    I think I might have found a used truck 2000KW, owner has all paperwork as about 800k owner said it was using a gallon every 15k instead of adding he was just did pm on it. Just had a overhead done at Cat they said don't worry about a gallon. Truck is getting 7.1mpg with light loads. Gonna test drive Saturday. Any input is welcomed as always.
  3. Diesel Dave
    9,767
    33,658
    Jan 20, 2010
    Hesperia, Ca.
    My 3406E 5EK when I down one gallon its usually time for service and thats about 12,000. I think your in good shape.
    colorado18spd Thanks this.
  4. 77fib77
    77fib77 Road Train Member
    11,747
    77,832
    Jul 7, 2010
    St Louis
    I drove a c-15 cat 2005 for seven months. It drank a galloon every 12,000 miles.
  5. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    My c-15 will use that much oil between services been that way since new so your all good there. But 800k is getting up there on the miles, if he hasn't done much with that motor you will be. Top end, main and rod bearings, turbo end play, excessive blow by, and other things of that nature should be on your mind with those kind of miles.
  6. colorado18spd
    396
    298
    Mar 10, 2013
    They put a new turbo on it but nothing internal done.
  7. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    My C-15 about the same, I usually change the oil around the time it needs a gallon at 12-15k. As far as having 800k it, get an oil sample, a good cat should get well into the million mile range. Plenty of cats that see the 1.5m mark. good luck
  8. colorado18spd
    396
    298
    Mar 10, 2013
    Went an took it for a test drive, the wheel seals where leaking on the drives. Offered 5k less than they were asking they said no I walked away.
  9. Largecar359
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    Yeah good call man. If nothing internal done on motor you can bet you'll be doing an in-frame in the near future.
  10. blessedman
    blessedman Light Load Member
    296
    230
    Feb 15, 2013
    Doniphan, Mo
    As others have stated I would not be concerned about the oil use, sounds good especially for that many miles. As far as the wheel seals that is not an expensive fix. Also if a truck has set for a while it is not unusual to have to replace some wheel seals when putting the truck back in service.
    Not saying to buy the truck, just that what you have said so far would not be a deal breaker to me. Depend on the price and the rest of the condition of the truck.
  11. 1988pete379
    1988pete379 Light Load Member
    193
    75
    Feb 28, 2009
    North East TX
    put it on dyno before you buy it .
