Oil consumption
Discussion in 'Ask An Owner Operator' started by Mandeepsingh, Nov 20, 2021.
  1. Mandeepsingh
    Mandeepsingh Light Load Member
    63
    23
    Aug 30, 2018
    Hey guys!
    I m back! I have to ask you guys this. So i just changed my shop for oil change and these new guys used baldwin filters and the older shop used to use fleet guard filters. So now i have oil consumption. Like 3 quarts in about 4k miles. I have a 2015 international prostar with cummins isx. The 2015 was a bad design by cummins so i got it overhauled like 240k miles ago. It has a total of 588k miles on it but the motor only has 240k. Please any help would be great. Thanks
  3. Mandeepsingh
    63
    23
    Aug 30, 2018
    Also, i forgot to add the truck has been deleted. And it has the new APR system with cummins.
  4. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    If you think the different filters are causing it, just put a Fleet Guard on and see if goes back to normal. Also, check around for new leaks. Especially around the drain plug or filter housing. Have you topped the oil back up and seen it fall short again? It's possible they never filled it all the way up too. Some shops prime the filter and some don't.
    GYPSY65 and feldsforever Thank this.
  5. Spyro2112
    Spyro2112 Medium Load Member
    626
    436
    Mar 17, 2018
    Burning it, not bad mine is a gallon every 3000 miles, one word
    REBUILD
    gerardo1961 and feldsforever Thank this.
  6. Mandeepsingh
    63
    23
    Aug 30, 2018
    Could it be the differential?
  7. Mandeepsingh
    63
    23
    Aug 30, 2018
    Okay i’ll check
  8. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Not at all.
    GYPSY65 Thanks this.
  9. Mandeepsingh
    63
    23
    Aug 30, 2018
    Alright! Thanks man
    ProfessionalNoticer Thanks this.
  10. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    I believe this is a known issue with Cummins. You have to go do their $800 oil change.
    It's a special cleaning oil
    feldsforever Thanks this.
  11. Lyle H
    Lyle H Road Train Member
    1,292
    2,942
    Apr 16, 2014
    I’m curious. Why would you ask if it could be the differential?
    GYPSY65, Roger McG and AModelCat Thank this.
