Oil field work related
Discussion in 'Ask An Owner Operator' started by Transportacion R&R, Oct 15, 2020.
  1. Transportacion R&R
    Transportacion R&R Light Load Member
    175
    73
    Apr 10, 2020
    I understand that we have another forum for oil fields but there’s crickets over there. Anyone working out in the oil fields in west Texas? How often are you changing your oil out there? Are you using rotella blended or full synthetic?
    thanks in advance
  3. lester
    2,959
    8,098
    Jan 2, 2012
    NW, Iowa
    I dont do oilfield but similar in the amount of dust and high idle time. I change oil at 10,000 miles and I use Delo oil. I also change air filters every few months. I'd like to put an hour meter on and go more on hours rather than miles
  4. Transportacion R&R
    175
    73
    Apr 10, 2020
    Thank you, yeah we don’t idle that much since we have an EPU. ( works and charges off different set of batteries ). I’m thinking more in the range of $15k, do you use full synthetic?
  5. lester
    2,959
    8,098
    Jan 2, 2012
    NW, Iowa
    I do not. I figure synthetic is more for the guys that go longer between oil changes. Awful expensive to change synthetic every 10k
    Brettj3876 Thanks this.
  6. Transportacion R&R
    175
    73
    Apr 10, 2020
    yeah im trying to decide if i want to do syntetic out in the oil field. I understand that more frequent oil changes out there in west texas do to the sand and harsh conditions, just trying to figure out how often i should go. most likely ill do 15k miles full syntetic
