Oil getting too hot
Discussion in 'Peterbilt Forum' started by irishluck09, Aug 17, 2020.
  1. irishluck09
    irishluck09 Light Load Member
    295
    180
    Nov 24, 2019
    96 pete 378 3406e 475hp
    My oil has been usually running at 210-220.
    This past week its been almost to 250* which us getting to hot. Just did an oil change yesterday too thinking it might help with no luck. My oil psi runs about 54-56.
    Wgt may be causung this and what do i need to replace here to get this under control?
  3. 77fib77
    77fib77 Road Train Member
    11,681
    77,117
    Jul 7, 2010
    St Louis
    Is it the sensor? Maybe a harbor freight temp fun , you can hit the oil pan see if it's close.
    irishluck09 Thanks this.
  4. irishluck09
    295
    180
    Nov 24, 2019
    Not sure if matters but i put a brand new sensor on the oil pan in April.
    77fib77 Thanks this.
  5. 77fib77
    11,681
    77,117
    Jul 7, 2010
    St Louis
    AMES 12:1 Infrared Laser Thermometer for $17.99
    I don't really know. The temp gun is like $20 with coupon. Which is the cheapest place to start.
    Pressure good so probably not a pump. Water temp is good, so not radiator. Is there an oil cooler?
  6. 77fib77
    11,681
    77,117
    Jul 7, 2010
    St Louis
    Is it real hot where you are at? Pulling hills at 79k?
  7. irishluck09
    295
    180
    Nov 24, 2019
    I have a temp gun ill have to grab from home.
    Water temp is pretty good holding at 190-200*. Fan kicks on around 205*
    Has round oil cooler on passwnger side of motor. Afraid it might be the issue
  8. irishluck09
    295
    180
    Nov 24, 2019
    Its abot 70* currently. Very nice out. Empty at 35000lbs running 60mph
  9. 77fib77
    11,681
    77,117
    Jul 7, 2010
    St Louis
    It doesn't make any sense.
    Does it sound like the engine is working hard?
  10. irishluck09
    295
    180
    Nov 24, 2019
    not at all. But thats why i also run at 60-65mph. I have 4.65 gears so pst 65mph shes pretty high up there in rpm's. But like i said its just this past week that it has gotten this hot. Usually runs at 220*. My concern is the oil breaking down because at 240* oil starts to break down
    D.Tibbitt Thanks this.
  11. xsetra
    xsetra Road Train Member
    5,197
    7,148
    Aug 21, 2011
    To help cool, does truck have a manual switch for cooling fan?
    Run with the fan on.
    This won't solve the problem but it will help keep the oil cooler.
    I have an N14
    Good luck.
