oil in coolant
Discussion in 'Freightliner Forum' started by simon999, Mar 9, 2014.
  1. simon999
    simon999 Light Load Member
    240
    95
    Feb 6, 2014
    I have freightliner detroit s60 egr. My coolant line from water pump to air compressor was leaking aliitle bit and I noticed on the cracked hose some oil near the compressor. I also noticed some oil in coolant reservour. My engine consumes about gallon of oil til 12k. My egr valve is closed. What could be the failure?Maybe anybody have expierience?
  3. Dakota1358
    Dakota1358 Medium Load Member
    431
    502
    Jun 15, 2009
    Staunton,Va
    possibly an oil cooler
  4. simon999
    240
    95
    Feb 6, 2014
    So need to remove oil cooler and do preasure test. Could this also be air compressor?
  5. bad-luck
    bad-luck Road Train Member
    3,435
    6,326
    Nov 16, 2013
    Baltimore, Maryland
    Oil cooler. .. but are you sure its not diesel fuel? Detroit series 69 are known for injecter cuo to leak fuel in the coolant
    DoneYourWay Thanks this.
  6. simon999
    240
    95
    Feb 6, 2014
    I saw white stuff in coolant, looked like grease.
