oil in radiator
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rbell116, Dec 13, 2014.
  1. rbell116
    rbell116 Bobtail Member
    18
    Feb 2, 2012
    st.matthews s.c.
    has anyone had oil in their radiator? had the coolant system pressurised at w.w. williams, they said everything ok
    they flushed the coolant system, drove a few days, and problem persist. any one know whats causing this?
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Pull a oil sample and have it ck. for coolant,Take it back and give them or another shop a chance to remove oil cooler and ck. it them install new seals, if they will pull the oil pan then press. rad. and turn over eng. by hand as they look for drops of coolant running out liners, we will all hope its seals being so close to new years !
  4. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
  5. aplustrucking
    aplustrucking Bobtail Member
    31
    Nov 19, 2014
    Sayre, Oklahoma
    Definitely oil cooler. Oil pressure is higher than coolant pressure
  6. rbell116
    18
    Feb 2, 2012
    st.matthews s.c.
    its in a Detroit and they tell me Detroit 60 series oil coolers almost never go bad. Do you think they full of crap? or are they correct?
  7. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,163
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    Almost never, isn't never is it?
    I'd vote oil cooler too, or should I say, for your sake I vote for the oil cooler......
    Martin
  8. OldHasBeen
    OldHasBeen Road Train Member
    1,269
    924
    Dec 16, 2010
    Years ago had that and it was the center head, just prior to that had a injector push tube break and fixed at the shop, next trip oil in the radiator. New head fixed it.
  9. TheLittleGuy
    TheLittleGuy Medium Load Member
    389
    64
    Apr 13, 2008
    Nashville, TN
    Check your oil for coolant in it! Antifreeze will make your mains swell and seize the crank! Been there and it ain't pretty.
    Also, determine if its engine oil or gear oil? Could be tranny cooler.
  10. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    210
    Jan 31, 2012
    Green Bay Wi
    and the longer you run it the more expensive it will get
  11. aplustrucking
    31
    Nov 19, 2014
    Sayre, Oklahoma
    It is the oil cooler. They are full of ####. You need to find a better shop if possible. Its an easy fix as long as the cooling system is flushed properly you should be fine. I've replaced a few over the years because they do go bad. I've seen it in CAT Detroit Cummins Mack and Volvo motors. Anything and everything on a truck can and will screw up. It was made by humans and it is an imperfect world, things do mess fineWith the oil cooler out you want have coolant in your oil as it just doesn't go that way unless the truck is parked for days and even then it probably won't get into your oil
    rbell116 Thanks this.
