So my truck has recently been leaking more oil than usual. I decided to take a picture, let me know if any of you guys see this as unusual because I think it is but I’m not sure. Thank you in advance.
Oil leak concern?
Discussion in 'Ask An Owner Operator' started by Mcast3092, May 14, 2022.
Page 1 of 3
Pretty hard to judge scale from your picture. Could be a 3inch puddle or 3 ft. How long did truck sit to make that puddle.
Doesn't take much to look like a lotGYPSY65 and God prefers Diesels Thank this. -
Puddle is about 6 inches wide. It took about 1.5 hours to make
I'd find out what's causing it at least. Then reevaluate from there.
Mcast3092 Thanks this. -
Yes that is what I am going to do, I’m just curious if that color is the cause of two liquids mixing. I see it’s come from a whole directly underneath the clutch
The brown colouring is oil mixing with clutch dust.
Most likely the rear main seal is blown. Could possibly be from another source inside the housing but 95% of the time its the rear main.Siinman, Dave_in_AZ, Mcast3092 and 4 others Thank this. -
I was told in the past to wait til I need a new clutch to change it. Would you say this is cause for concern?
Its your call. Personally I'd do it sooner than later and put a new clutch in while the transmission was out.
Opendeckin and Mcast3092 Thank this. -
As long as you're going to have it apart-
Replace the carrier bearing, clutch, bell housing gasket, and rear motor mounts.Bigtruckdrivah, 77fib77, InTooDeep and 4 others Thank this. -
You guys are the best! If it weren’t such hard times with fuel and rates being so low itd be first on my list. I’m going to have to budget it in. Really appreciate you guys thank you so much
ProfessionalNoticer Thanks this.
Page 1 of 3
