Oil Leak parts
Discussion in 'Volvo Forum' started by rhitrucking, Feb 24, 2020.
  1. rhitrucking
    rhitrucking Light Load Member
    163
    73
    Feb 7, 2017
    Truck is due for an oil change, but noticed its leaking from the fill tube to oil pan. I want to get whatever is needed to fix it before I start the oil change. Is there a gasket or o-ring that needs replacing?
  3. Freightliner Classic
    Freightliner Classic Light Load Member
    108
    98
    Dec 17, 2018
    Rome GA
  4. rhitrucking
    163
    73
    Feb 7, 2017
    Volvo D11..but I think the setup is the same as the D13
  5. rhitrucking
    163
    73
    Feb 7, 2017
    Nevermind. Looks like there is a sealing ring that goes in there. In case anyone cares its part 21780376
  6. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Just replace the whole tube and seal. The plastic funnel/tube break at the bellows.
    Doealex, QUALITYTRUCK and rhitrucking Thank this.
  7. rhitrucking
    163
    73
    Feb 7, 2017
  8. vacaflortoro23
    vacaflortoro23 Bobtail Member
    8
    Hi, I have a Mack SXU VISION 2014 with motor D13 MP8.
    I have a leak in the exhaust leak with the smell of oil and gasoline
    I have checked the head and the turbo, and both are good
    Does anyone know what else should I check?
    VIDEO WITH LEAK
  9. AModelCat
    166,497
    How long are you idling for? Looks like fuel slobber from not being run hard enough.
    Goodysnap Thanks this.
  10. QUALITYTRUCK
    1,821
    1,789
    Jun 14, 2009
    romulus,mi
    I am not joking about the following statement. If you are saying that you "smell oil and GASOLINE" take your truck to someone or some place that is familiar with diesel engine repair.
    loudtom, Socal Xpress and AModelCat Thank this.
  11. AModelCat
    166,497
    I agree. I was going under the assumption it was a freudian slip.
    loudtom and QUALITYTRUCK Thank this.
