Oil leak.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BRD TRANSPORT, Mar 24, 2024.
  1. BRD TRANSPORT
    BRD TRANSPORT Light Load Member
    184
    69
    Jul 6, 2018
    Had no leaks on my C15 Acert 475. except a moist small bleed comming out or rear oil seal.no worries.
    Had an oil change and service guy asked if I wanted lucas oil treatment.
    I said sure being in a good mood . Being gone 2 weeks headed home.
    45 miles later I was leaking oil around my oil pan gasket
    W T H happend.
  3. Big Road Skateboard
    7,096
    40,257
    May 2, 2021
    You're certain it's not a problem with the filter?
    Absolutely nothing about the Lucas will cause issue with the gasket
  4. Diesel Dave
    9,654
    32,689
    Jan 20, 2010
    Hesperia, Ca.
    Dump the Lucas, drop Wally World Gear oil instead. Half the price and your putting the strip additives back in your oil.
  5. BRD TRANSPORT
    184
    69
    Jul 6, 2018
    Will definitely check it out.
    Weather has made it tough to get under and check.
  6. W923
    W923 Road Train Member
    1,419
    4,389
    Feb 28, 2022
    Possibly oil from the rear seal is following the pan gasket
    Maybe some of the extra dipstick holes that are plugged are leaking and following the pan gasket (this seems to be pretty common). maybe the pan gasket is actually leaking
  7. Magoo1968
    Magoo1968 Road Train Member
    2,056
    5,477
    Mar 18, 2021
    St Malo mb
    My experience with a c12 after adding Lucas was oil pouring out of blowby tube on a 50000 mile rebuild also was pushing out dipstick. Next oil change none was added and oil consumption stopped. Mechanic couldn’t explain it other than saying it somehow caused crankcase pressure to build up.
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Lucas is really thick. I put it in a Cummins N14, it puked it all out the same day. Topped back up with normal oil, normal consumption resumed.
    Magoo1968 Thanks this.
