Oil pan gasket
Discussion in 'Ask An Owner Operator' started by Spyro2112, Apr 22, 2026.
  1. Spyro2112
    Spyro2112 Medium Load Member
    643
    447
    Mar 17, 2018
    14 prostar isx 15.
    Want to change dealer want 300. Any suggestions? On what kind or whom to seek for 1. Is permtex. Recommended?
    Friend and D.Tibbitt Thank this.
  3. abyliks
    abyliks Road Train Member
    4,186
    9,900
    May 2, 2010
    ludlow MA
    I’d be estatic to have only a $300 repair
    D.Tibbitt and Diesel Dave Thank this.
  4. Diesel Dave
    9,836
    34,265
    Jan 20, 2010
    Hesperia, Ca.
    Are you sure it’s the oil pan gasket ? When I purchased my 2014 with the ISX 15, I thought exactly the same thing. It was all oily around the pan. When I got home, I pressure washed the whole motor clean, I started the truck and let it run for a few and behold, the gasket from the fuel pump was the culprit. Not a drop from the oil pan.
    Oxbow, Friend and D.Tibbitt Thank this.
  5. RunningAces
    RunningAces Road Train Member
    1,309
    2,590
    Jul 2, 2017
    Or it could be the front main seal. On ISx15s especially. The oil will leak down and run along the pan.
  6. D.Tibbitt
    158,616
    Its a perfectly fine price. Have u ever tried to wrestle an isx oil pan off? Its not very fun.. incredibly heavy and awkward and like 20 something bolts to tighten and torque... And yes the book calls for some anarobic sealer to be installed on all 4 corners of the pan...
    I mean you could do the job urself. But $300 isnt that bad...
    Oldman83, Friend and Diesel Dave Thank this.
  7. 062
    062 Road Train Member
    6,358
    34,077
    Oct 20, 2013
    Maybe OP is saying the price of the gasket itself is $300
    Diesel Dave, lester and D.Tibbitt Thank this.
  8. D.Tibbitt
    158,616
    Oem cummins sounds about right im sure aftermarket is cheaper...
  9. RunningAces
    1,309
    2,590
    Jul 2, 2017
    Oh yeah, make sure you torque it back to the correct specs and order. Then check it because the #### things will often vibrate loose. It's not hard, just a pain in the ###.
    Oldman83 and D.Tibbitt Thank this.
