I got a used 2011 cascsdia with a DD15 and was going to change the oil but, this truck has a different plug than I'm used to seeing. This truck has a 12 mm hex socket and has a kinda locking plate that is behind the hex head. does anyone have an idea or have removed this style of plug. Thanks
Oil plug removal.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 3ARTransport, Jun 22, 2016.
They have a composite oil pan. I wonder if it got stripped out and you're looking at the repaired one.
3ARTransport and Brandt Thank this. -
Not to shur about the pan, the other cascsdi I have has that hex head style removed and a real drain plug installed
I use one of these. Once installed you never have to worry about someone over torquing it.
https://www.nospillsystems.comrabbiporkchop, blairandgretchen and 3ARTransport Thank this. -
That's what I need, if I could only get this one off. Thanks
Take a pic maybe?
Will do.
Mudguppy Thanks this.
Dang, that's new to me. So the hex bolt is attached to the plate thing?
Sorry man, I'm stumped, but I'm sure someone much smarter than me will be along to solve it. Good luck.
