oil pressure gauge going nuts
Discussion in 'Ask An Owner Operator' started by MBunt387, Feb 3, 2013.
  1. MBunt387
    MBunt387 Light Load Member
    165
    46
    Mar 24, 2012
    Your Moms house
    I recently got my B service done at rush truck center in mobile Alabama, I have an 08 Pete 387 with Cummins isx450. Once I got on the road, my oil pressure gauge has been going crazy, it'll run fine for a few hours at the right range, then drops to 0 psi then maxes out then back to 0. Headed to shop tomorrow, was just curious if anyone has had this issue and k ow of a fix. Hoping to save some $$$ thanks
  3. rickybobby
    rickybobby Road Train Member
    4,843
    6,672
    Jul 10, 2010
    greensboro, nc
    Its probably the oil sensor..
  4. brysol01
    brysol01 Medium Load Member
    320
    460
    Nov 2, 2009
    yes, after a while it will start derating your motor, leaking pressure sencer, they showed me where it was leaking through the sencer to short out the wireing, it didn't shut down the motor at first but the longer it happened, started to derate the motor after it would swing back down to zero, in not very handy places i might add
  5. Allaby
    Allaby Light Load Member
    70
    17
    Aug 17, 2011
    Macungie, Pa
    prob oil pressure sensor, my century does that same thing also does it depending on outside air temp. I read something also about atmospheric pressure sensor cause that too look into it man!
  6. MBunt387
    165
    46
    Mar 24, 2012
    Your Moms house
    Thanks everybody for the responses. It ended up being a shorted out wire. Anyways thanks again.
  7. Allaby
    70
    17
    Aug 17, 2011
    Macungie, Pa
    10-4 glad you found it, that gauge drive me nuts i always think something crazy is gonna happen when it starts bouncing, especially 1200 miles from home. stay safe out there bro.
