Oil Pressure Gauge Problems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Jinxmiceter, Feb 16, 2019.
  1. Jinxmiceter
    Jinxmiceter Bobtail Member
    4
    Feb 16, 2019
    I have a 2011 International prostar with the ISX15 liter Cummins, My oil pressure gauge maxed out, then dropped down to 5 pounds of pressure, then goes into shut down mode. Everything I have read states to change the oil pressure sending unit. I did so, after doing so the gauge seemed to have worked properly for approximately 10 minutes then it maxed out and once again dropped back down to 5 pounds of pressure, when I accelerate the engine the gauge does not move. The motor is not making any noises, and Is full of oil.
    Has anyone ever encountered this problem on their truck can you give me any ideas of what to look for.
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,813
    Jan 27, 2013
    Phoenix, AZ
    I had a similar problem years ago in my '01 Volvo. Problem ended up being a loose wire on the circuit board in the dash cluster.
    Jinxmiceter Thanks this.
  4. olddog_newtricks
    olddog_newtricks Medium Load Member
    639
    2,164
    Jun 3, 2018
    If the sending unit didn't fix it I would try changing the oil pressure gauge.
  5. IH Truck Guy
    5,230
    61,089
    Mar 2, 2008
    Purgatory
    Plumb in a mechanical gauge and see what that reads.
    BoxCarKidd, A5¢ and Jinxmiceter Thank this.
  6. Jinxmiceter
    4
    Feb 16, 2019
    That's my next move. But how do i keep engine from shutting down?
  7. IH Truck Guy
    5,230
    61,089
    Mar 2, 2008
    Purgatory
    Ok you didn't say it was shutting down .
    So it drops to 5psi,warning lites come on and it shuts down?
  8. Jinxmiceter
    4
    Feb 16, 2019
    Exactly
  9. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    I would go ahead and instal the manual gauge. I’m not sure on Cummins, but sometimes you can fool the computer by unplugging the sensor.
    If it’s not an electrical issue, more than likely you have a sticking oil pressure relegated valve.
    If you start it and max out the manual gauge start looking for threads involving an ISX and oil pressure relief, you should find somebody more familiar your engine.
  10. Jinxmiceter
    4
    Feb 16, 2019
    Replaced oil pressure switch.. and plug, took care of problem. Thank you for everyone's suggestions.
    Working2party and IH Truck Guy Thank this.
  11. Dmaksymchuk
    Dmaksymchuk Bobtail Member
    Replace Oil Pressure Sensor. Mine was doing same thing and I got my problem fix. Check the link below
    Location Oil Pressure Sensor
    When I replaced the Problem went away.
