Oil pressure Issues 2015 Freightliner Cascadia
Discussion in 'Ask An Owner Operator' started by BWEST160, Jan 13, 2021.
  1. BWEST160
    BWEST160 Bobtail Member
    Mar 2, 2020
    Hello having issues with my oil pressure. Truck runs for days or months then out of the blue oil pressure gauge fluctuate and truck jerks a little, then check engine light cuts on and oil light comes on and pressure drops to 0. Pull over then pressure goes back to 30. Take to shop but all they say is it needs a regen and changed my oil pressure sensor. After the fourth time this happened went to a new shop with the same issue and check engine light on. They changed my high pressure line kit. This was Monday today is Wednesday and the truck jerked and the oil pressure gauge went crazy parked. Has anyone else have these issues?
  3. Brandt
    Brandt Road Train Member
    4,647
    6,421
    Sep 17, 2012
    Detroit engine have or had trouble with oil pickup tube. Something about it plastic in the DD15 engines and I think the seals go bad from engine heat. The rubber seal cracks or something and then it suck air instead of oil up from oil pan. Just a guess that might be you problem.
  4. 77fib77
    77fib77 Road Train Member
    11,936
    79,497
    Jul 7, 2010
    St Louis
    What engine? Year? Truck make? Miles?
  5. OldeSkool
    OldeSkool Road Train Member
    2,128
    6,994
    Jul 17, 2018
    New Hampshire
    I have a 2017 Freightliner Cascadia DD13 doing the same thing. Hopefully you got it figured out so you can help me.
  6. msh
    msh Light Load Member
    159
    110
    Jul 18, 2021
    Los Angeles, CA
    stop the truck. change the suction manifold. if odometer is near 700k change oil pressure sensor too..
