Oil pressure on Volvo D13 Engine
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by wallance, Feb 21, 2018.
Page 2 of 4
Thank you so much for your advice! But could you judge what is the really reason for the low oil pressure? I want to fix the problem totally.My truck will go from CA -AL tomorrow.
Thank you so much for your advice! But could you judge what is the really reason for the low oil pressure? I want to fix the problem totally.My truck will go from CA -AL tomorrow. -
Thin oil = low pressure <---- IN MY TRUCK.
only way is to do a pressure test and trace where there's a leak in the fueling system.
Since fuel is moving from its normal environment into crankcase, conclusion is that there's a leak somewhere, before it gets into the cylinder.
A dye test and pressure test will tell you and it will involve removing the top cover.
2hr effort by a competent mechanic will answer that.Last edited: Feb 24, 2018
wallance Thanks this. -
After two nights, my fresh engine oil become more and coolant decrease a lot.That means my coolant leaking so fast! Any fast way to check where is leaking? I am going to drive 2000 miles this afternoon to AL.
I WORRY MY ENGINE SHUT DOWN ANYTIME. -
It the problem of radiator or Cylinder gasket ?
what color is the oil when you check with a dipstick?
are you seeing white smoke coming out of the exhaust? -
oil is the color like normal and not see the white smoke.
1000 miles has been driven, now on the way to AL.But oil pressure drop drown to 31~32.No warning come up yet.
Should I go to dealer? They will take few days to fix it.
Please advise. -
If the oil isn't milky, you probably have fuel getting in the oil. You should take an oil sample to confirm. No point in chasing a coolant leak if its fuel dillution. You have a lot more balls than I to run a truck that long with that issue. You're playing Russian Roullette with a loaded gun with that engine. Cross your fingers you haven't wiped out the cam or crank bearings.
Broke Down 69 Thanks this.
Page 2 of 4
