Oil pressure problem DD15
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Bibin, Jan 8, 2018.
  1. Bibin
    Bibin Bobtail Member
    28
    5
    Oct 10, 2013
    Oil pressure.Check engine light and "stop engine " on low RPM. On high RPM everything like to be normal. Cascadia DD15 year 2013. Oil pump or something else? Please help.
    Thank you.
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Leaking/rock hard o-rings on oil pump pick up tube/ transfer pipe manifold.
    jamespmack, uncleal13 and Bibin Thank this.
  4. Bibin
    28
    5
    Oct 10, 2013
    Thank you. I'm little bit confused? Do I need replacing all of this tings?
  5. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    What does your gauge read at idle and running down the road?
  6. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Usually needs just o-rings that are bad. Cost more in labor than parts. Have to raise frame to get oil pan to fit past front cross member. Jack between spring and frame works.
    BoxCarKidd and Bibin Thank this.
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    It’s not a big job, in and out the same day. Could be done yourself if you’re mechanically inclined.
    Bibin Thanks this.
  8. brysol01
    brysol01 Medium Load Member
    320
    460
    Nov 2, 2009
    roll bearings at the same time
    Bibin Thanks this.
  9. Bibin
    28
    5
    Oct 10, 2013
    Thank you very much for your time and information.
    brysol01 and uncleal13 Thank this.
  10. Bibin
    28
    5
    Oct 10, 2013
    Thank you guys. Truck is fixed.
    uncleal13 Thanks this.
  11. uncleal13
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    How much did it cost? And what was the problem they found ?
