Oil pressure sensor PLS HELP!!!!
Discussion in 'Volvo Forum' started by Volvoslave))), Aug 3, 2016.
  1. AModelCat
    164,645
    I would look into plumbing a mechanical test gauge in to the engine. That way you can eliminate the problem as either a gauge/wiring problem or an internal engine problem.
    Volvoslave))) Thanks this.
  3. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Well Electrical Issue will not cause oil pressure flutering between values, and the value to low means that there is a mechanical issue and the oil psi is actually to low. best way to go is check with a mechanical gauge and see if you hav the same outcome
  4. cumminskid123
    cumminskid123 Light Load Member
    107
    59
    Jun 21, 2016
    Manitoba, Canada
    Please post an update when you have a chance of what the problem was, your findings, and the fix. :)
  5. Volvoslave)))
    Volvoslave))) Bobtail Member
    17
    6
    Aug 2, 2016
    I will because f... Thing drive me crazy.
    Will go to the dealer and give them that sensor back and take another one.
    Volvo said it might be sensor problem try to replace it
  6. cumminskid123
    107
    59
    Jun 21, 2016
    Manitoba, Canada
    like the two replies above, you should really put an adapter and mechanical gauge, rule that out first, if the mechanical gauge fluctuates, you have issues with the bottom end without a doubt
  7. Volvoslave)))
    17
    6
    Aug 2, 2016
    It is right BUT. Oil pressure may exist or not . its white or black no grey. Mechanical yes or no! But here. Maybe come up )))) in a certain temp and rpm
  8. Gerry_C
    Gerry_C Bobtail Member
    17
    9
    Jan 15, 2015
    If the Mechanical gauge reads steady, have someone watch the dash gauge while idling and another pushes/pulls/yanks/thugs on the wire and harness from the sending unit clear to the firewall, it steady while doing that try the inside of the firewall if you can reach. It could be a bad wire or plug somewhere.
  9. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    My suggestion up to be at the dealer, can you run a test gauge with the cluster menu ?
    If so, run it 3 up to 5 times and look if your oil pressure gauge needle is doing the same cycle every time ?
    It can help to identify a cluster issue !
    Another question is your engine brake (VEB) work like normal when the oil pressure problem is there ?
    Because VEB need good engine oil pressure to run like expected, if your VEB is weaker than normal when the oil pressure is moving then you will know you have a mechanical oil pressure issue.
    Hope this can help.
    Ben
  10. Volvoslave)))
    17
    6
    Aug 2, 2016
    Thanks to everyone who replayed. So update sensor was replaced free of charge. Everything be come a normal!!!
  11. ryanbob1
    ryanbob1 Light Load Member
    121
    35
    Sep 9, 2016
    electrical problem spray ratpiss in plug and trace wire back and see if they are rubbed through somewhere
