oil pressure
Discussion in 'International Forum' started by turner63, Mar 30, 2015.
  1. turner63
    turner63 Bobtail Member
    9
    Have a lonestar with cummins isx 600 horsepower engine oil pressure was 40 when I left home and engine temperature was around 155 as the truck runs longer during the day oil pressure was down to 20 and temperature was going up to 215 before settling back down to 195 causing warning light to come on and restricting power oil temperature was around 200 it seems the engine temperature gage is moving all over the place feels like the truck only has 400 horsepower as our 475 cats pulled away up the mountain already 3 loads and 3 trips to dealership can't find problem only 380000 miles on engine
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Those temps are perfectly normal. Nothing wrong with 20 psi at idle.
  4. turner63
    9
    Thanks heavyd. But the oil pressure was under 20 at 1800 r.p.m. not idling plus loosing power
  5. tucker
    tucker Road Train Member
    12,647
    40,425
    Jun 13, 2008
    IN
    On My last 2010 Prostar with the Cummins, it'd plug the oil filter up with soot and at 20psi it would kill the motor.
    Just a filter change and it'd run about 40psi again.
    scottied67 Thanks this.
  6. turner63
    9
    Tucker I did that the next oil pressure drops again truck very sluggish
  7. turner63
    9
    Could the imap.sensor be the problem
  8. d60-14
    d60-14 Light Load Member
    72
    30
    May 23, 2012
    You have an internal Engine problem, for the oil pressure to go that LOW (if the gauge is correct) you have main bearings failed or oil mixing with fuel. Whatever the reason, DO NOT DRIVE IT until you find the cause. For a start - check the motor oil for fuel smell...
  9. reefer101
    reefer101 Medium Load Member
    444
    246
    Oct 24, 2014
    20 is not good. in ISX it should be over 30 with hot oil and 1800 rpm. you proubebly need to replace crankshaft bearing shells
  10. SunnyRoadTrucker
    SunnyRoadTrucker Bobtail Member
    38
    15
    Sep 1, 2014
    Elk Grove Village. IL
    Do you have CHECK ENGINE ECU AT NEXT STOP light ON???
    If yes!!!
    Change your oil Pressure Sensor!​
