Oil Test
Discussion in 'Ask An Owner Operator' started by blue1005, Sep 3, 2019.
  1. blue1005
    blue1005 Light Load Member
    157
    87
    Apr 18, 2015
    I see people talking about testing their oil. What can this show, how can it help, and where can you do this? I saw one place in houston but that is all. Links would be really helpful, and prices also. I appreciate you.
  3. AModelCat
    165,170
    It will tell you the condition of the oil, wear materials suspended in the oil, possible contaminates in the oil (coolant, dirt etc).
    If you do them every oil change, you can spot trends. Say for example you start seeing elevated levels of coolant in oil, you can start to budget and schedule downtime for a repair. Rather than be stuck out on the road at an unfamiliar shop.
    Lots of companies provide oil sample services but I'm only really familiar with Caterpillar SOS, which I believe is not exclusively for CAT brand engines. The other name I hear tossed around is Blackstone but have no experience with them.
    blue1005 Thanks this.
  4. JonJon78
    JonJon78 Road Train Member
    7,246
    43,303
    Jul 1, 2018
    Blackstone labs in Ft. Wayne, Indiana... Google them. They will send you the sample bottles then once you get your oil changed have a sample taken and mail it off... Results will be emailed to you... Having my oil changed as I type this... 15675391513052627524942988859481.jpg
  5. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Oil analysis will tell you almost everything about your engine.
    Elevated levels of chemical elements points to the problem.
    Si, Na, Mg - Road dust, air filter not sealed, small amount if coolant in oil.
    Iron - piston cooling nozzle, air compressor, fuel pump.
    St, Al, Co(tin, aluminum, copper) main and camshaft bearings. If copper is in analysis the bearing life is close to the end.
    You can have oil test in many exSpeedco loacation. If test came bad retest oil after 1-2 thousand miles in any other service. Many CAT dealers have it, Blackstone for example. You can order it by the mail and send them sample.
    Truemac and stillwurkin Thank this.
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Saved me from dusting my engine. Samples read great, all of a sudden, silicon, potassium, iron, aluminum all up.
    Found a loose clamp on turbo intake, was sucking in road spray in the winter.
    Rounded_nut, Snailexpress and blue1005 Thank this.
  7. xsetra
    xsetra Road Train Member
    5,199
    7,151
    Aug 21, 2011
    Same comments as previous posters.
    Search
    motor oil sample testing
    I use local Cat service.
    I think they give better analysis than US Lube and Speedco.
    And this Cat branch will call you if you have a problem that needs attention immediately.
    $17.00 includes postage if I buy the kit at Freightliner dealers in Wisconsin.
    Good luck
  8. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    I must be doing it wrong. I've had my engine overhauled one's since 1997
    Going on 2 million miles never had a
    Oil test...
  9. olddog_newtricks
    olddog_newtricks Medium Load Member
    639
    2,164
    Jun 3, 2018
    Speedco offers oil testing. How accurate is it? I couldn't say.
  10. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Not accurate at all. Use one of others like Cat, Blackstone or OPS.
  11. JonJon78
    7,246
    43,303
    Jul 1, 2018
    They dont offer testing anymore.
