OIL TURBO ISX
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Brightlog, Jul 2, 2019.
  1. Brightlog
    Brightlog Bobtail Member
    43
    10
    Jun 8, 2019
    Oil in turbo and interchanger radiator cooler what dose this mean?
  3. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    seals going out. I had a very fine mist for a while in my intercooler elbow. I let it go for a month.
    There was no shaft play but who knows, i replaced it anyway. Wouldnt want that to self destruct while on the road.
    Intothesunset and Brightlog Thank this.
  4. Brightlog
    43
    10
    Jun 8, 2019
    When you say seals. You referring seals from turbo ?
  5. Brightlog
    43
    10
    Jun 8, 2019
    Do I have to replace my turbo? or get it cleaned ?
  6. flood
    flood Road Train Member
    4,169
    4,053
    Dec 25, 2010
    replace the turbo
    if the seal is bad odds are the bearing will be next
    Cam Roberts Thanks this.
  7. Goodysnap
    Goodysnap Road Train Member
    3,811
    9,296
    Jul 12, 2017
    If this is a VGT the Holset turbocharger does not use seals. Check the impeller for axial and radial movement. If there is evidence of of the rotor hitting the housing the bearings are already worn beyond their serviceable life. It will most likely need to be replaced.
    Any oil on the exhaust side? Also make sure the oil drain is open and not blocked. If the drain is plugged it will force the oil out from the wrong places.
    Cam Roberts and QUALITYTRUCK Thank this.
  8. Cam Roberts
    1,621
    1,938
    May 13, 2018
    that pic you posted is exactly what i had going on. Yeah when that starts to leak, its best to replace the turbo. Its time. What turbo is on the truck?
  9. Brightlog
    43
    10
    Jun 8, 2019
    It’s a 2009 dose this help?
  10. Goodysnap
    3,811
    9,296
    Jul 12, 2017
    CM 871 or CM2150 both are most likely Holset VGT if stock.
    Provide ESN to be sure.
    You will need to clean the CAC of oil and inspect the DPF for oil saturation. If your lucky it's only coming out the compressor side.
    Have one in the shop now. Found the hot side blade and shaft all the way down at the DOC. It made a huge mess. Oil was running out of the DPF/ SCR.
    spsauerland Thanks this.
  11. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
