oil usage and rebuilt engine
Discussion in 'Freightliner Forum' started by Cybercat, Nov 21, 2015.
  1. Cybercat
    Cybercat Medium Load Member
    605
    554
    Oct 17, 2014
    East Tn
    What is good oil usage per week for Detroit series 60 that was just rebuilt? It has 8000 miles since rebuild. Putting in a gallon a week and not babying it. Wondering if this is normal and if so when it should taper off a bit.
  3. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    What oil are you running
  4. Cybercat
    605
    554
    Oct 17, 2014
    East Tn
    Mobil 1 synthetic. It's what the mechanics use for company truck and the engines they rebuild.
  5. Accidental Trucker
    Accidental Trucker Road Train Member
    3,442
    7,845
    Jun 4, 2015
    I'm at six thousand miles on mine, and added my third gallon. Just did a PM, with regular dynosaur oil, hoping the fresh oil helps.
    Sure hope the rings are seating.......
    Cybercat Thanks this.
  6. Bogi
    Bogi Light Load Member
    114
    31
    Jul 15, 2013
    Elk Grove Village, IL
    it takes oil first 10K miles, that's normal
    you good for next 10 year, 1M miles :)
  7. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    That don't sound right to me.
    That's alot oil
    My reman series 60 in my truck will be down 1 gallon after 10,000 miles. Regular delo400
    Been that way since new.
    Gallon a week I'd freek
  8. Accidental Trucker
    3,442
    7,845
    Jun 4, 2015
    yeah, I'm freaking a little. It sure seems to me the rings aren't seating properly.
  9. Fajo
    Fajo The Dark Knight
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    I had my ISX Rebuilt here about year ago. To this day still does not use one drop of oil between changes.
  10. Bogi
    114
    31
    Jul 15, 2013
    I'm sure, because I did overhaul on my 1999 Detroit 60 12.7
    after the overhaul, I did my first oil change 5K after, second on 10K miles, and then by now I'm doing at 13K
    and I'm telling you, taking oil like crazy first 10-15K, then this oil consumption disappear
    you have nothing to worry about, trust me
    Cybercat and Accidental Trucker Thank this.
  11. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    How much oil it uses per week depends on how many miles per week and the quality of the parts. If they were genuine Detroit parts and the work was done correctly, you should not be using that much oil. Aftermarket parts may require a longer break in. The last S60 I in-framed used about a gallon it's 1st 10,000 miles, when I did the initial oil change. After than it only uses about a gallon every 15,000 mile oil change and has a little over 200,000 on it now. A quality hone and rings are pretty much broken in out of the box these days. Cheaper aftermarket parts may still do things the old school way, course hone, hard rings and a long break in time.
    Accidental Trucker Thanks this.
