Oil usage between oil changes
Discussion in 'Experienced Truckers' Advice' started by Otrliveload, Jul 17, 2019.
  1. Otrliveload
    Otrliveload Bobtail Member
    22
    7
    Oct 8, 2018
    So i have a 19 mack anthem with the mp8 motor in it. Would using 1.5 gallons of oil be acceptable to burn in 37,483 miles? No visible leaks anywhere except the blowby tube is little oily. Had oil changed at 70,117 miles and now were at 107600 miles since last oil change. They require you to use 10w-30 oil in this motor.
  3. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Wouldn't bother me at all
  4. DUNE-T
    DUNE-T Road Train Member
    6,978
    16,934
    May 10, 2015
    Detroit, MI
    Oil change every 37k miles. Mama Mia!
    FlaSwampRat, Mark E7, starmac and 8 others Thank this.
  5. Otrliveload
    22
    7
    Oct 8, 2018
    Thank you very much for the info
  6. Otrliveload
    22
    7
    Oct 8, 2018
    Truckermania Thanks this.
  7. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I wouldn't follow those oil change recommendations. Your a fool if you think the manufacturer has your best interests at heart with those intervals.
    Sure sells parts thou!
    As for the oil usage, totally acceptable for that kinda mileage. If you changed the oil at 20,000 you probably wouldn't have to add any.
  8. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    You didn't read the whole thread. lol
    faux_maestro Thanks this.
  9. MartinFromBC
    2,769
    12,478
    Oct 19, 2018
    That is nothing for oil use. Heck try a cummins, those suckers burn so much oil I was ready to buy a refinery.
    Orange713 and FlaSwampRat Thank this.
  10. Brandt
    Brandt Road Train Member
    4,527
    6,219
    Sep 17, 2012
    Detroit Diesel don't burn oil
  11. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    but they leak it. a 12.7 was known for the top cover leaking oil.
    Rideandrepair, FlaSwampRat and Brandt Thank this.
