ok so the big debate/ rant
Discussion in 'Experienced Truckers' Advice' started by peabody747, Jan 31, 2023.
  1. peabody747
    peabody747 Light Load Member
    231
    253
    Jan 1, 2022
    First of to the ones that seen I was missing a parking light on back of tractor yes I know its frickin out, I don't have 1000s for them to inspect the wiring harness.
    Now the debate, since my light is out on the tractor will dot give me a ticket while hooked to a trailer?
    I say yes cause the rule is all lights must work, friend says no cause its covered by the trailer....
    go ahead trucker forum lawyers let the debate begin
  3. nikmirbre
    nikmirbre Road Train Member
    5,590
    10,358
    Jul 27, 2011
    High Point NC
    There's no debate, idk if you'll get a ticket but yes, it is a DOT violation.
    Just like if you dont have mudflap while hooked to a trailer, youre OK.
    However, if you have the mudflap bracket on and no flap/reflectors, thats also a violation.
  4. REO6205
    REO6205 Road Train Member
    13,168
    60,500
    Feb 15, 2014
    California.
    Sometimes a light being out is a simple repair. Look for broken wires, especially at butt splices. Look for the simple stuff first. No need to go right to a shop and spend shop rates for something minor. Learn to fix things yourself.
  5. Long FLD
    Long FLD Road Train Member
    12,910
    54,149
    Mar 4, 2015
    Legally it’s a required light even with a trailer.
    I’d start by cutting everything apart where it’s bundled together at the back of the frame. If one side works normal and the other side doesn’t it’s usually pretty easy to inspect the wires going to the inoperable side, especially if only one function of the light isn’t working.
    nredfor88 and God prefers Diesels Thank this.
  6. Ridgeline
    22,732
    123,563
    nredfor88, RubyEagle and tscottme Thank this.
  7. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    No, the rule is all required lights must work. Additional lights are not required to work. That is not guidance, it is in the regs themselves. 393.9(a) states: “All lamps required by this subpart shall be capable of being operated at all times. This paragraph shall not be construed to require that any auxiliary or additional lamp be capable of operating at all time
  8. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Both are wrong.
    If it's a required light it must work. If it's a light that's not required then it doesn't have to work. Having a trailer hooked up or not has no bearing if it's a required light or not.
    For a list of required lights read the FMCSA 393.11
    Federal Register :: Request Access
    Also, to those saying all lights must work read the last sentence @Bean Jr. just posted, burn it into your mind. That way you will stop spreading incorrect information
  9. kemosabi49
    10,978
    47,920
    Jan 13, 2013
    SW Arkansas
    I was inspected and the left center tail/brake light was out. Just the tail light. The brake light part worked fine. Cop told me that there was no violation as I only had to have 2 tail-lights, 2 brake lights and turn signals. He said I would be legal if all were combined into having only one light on each side. Tail/brake/turn signal combined as on the tractor or some 4 wheelers.
    Although I'm glad I didn't get a violation, I'm not sure he was right. @ZVar what do you think.?
  10. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    Ask 10 so called qualified DOT inspectors the same question
    Guarantee you’ll get 10 different answers
    Best to have everything up to snuff
    Jus Sayin
  11. bryan21384
    bryan21384 Road Train Member
    15,744
    34,319
    Sep 18, 2009
    Memphis, TN
    Only if you get caught by a sour DOT officer.
