Old TMC benson flat
Discussion in 'Flatbed Trucking Forum' started by hazzmatt89, Jun 11, 2025.
  1. hazzmatt89
    hazzmatt89 Light Load Member
    64
    56
    Oct 3, 2023
    Iv looked in the search and find few things so figured I’d make a post. I got a 10k budget can’t finance looking for a flatbed. I found an 2000 benson 48-102 spread with chain pulls and guy said it was an old TMC trailer. Guys asking 8k it just came off the road. Iv talked to a couple guys and get a bunch of different opinions on these trailers. One local guy has the same one and seems to be holding up same year etc.
    He’s had it for over 10 years looks in good shape from pictures says he’s hauled coil to general freight.
    I haul local and normally do Atleast 1/2 coil a week most is 43k steel coil and those are only normally every few weeks the rest is normally under 35k , mixed with aluminum, lumber, plates, mulch, brick.
    right now I’m renting a Transcraft and it gets the job done everyday
    Walk Among Us Thanks this.
  3. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,956
    Oct 31, 2023
    10k is really low and 8 grand sounds more like a scrap trailer. Aluminum trailers crack from work hardening over time and belly loading is tough on any trailer.
    TMC will spec the cheapest trailer they can get. Hauling heavy on a light trailer is much more damaging than running a heavier specced trailer loaded well below its max capacity.
    Is it one of their Fantaines or Bensons?
    I'd learn about where the common places that particular trailer tends to crack and look at it yourself in person. Or have a dealer go over it in known problem areas if you can't do it yourself.
    Walk Among Us and Ruthless Thank this.
  4. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    That old Benson will pull nicer than your rental. TMC will have ordered it with the coil package. Definitely go over it with a magnifying glass, looking for cracks. If you buy it, pull the wheels, inspect/replace the bearings and replace the seals, check the bushings, new shocks, and get it aligned. It’ll be a nice trailer to work with, if it’s not cracked.
    Walk Among Us and Ok big boy Thank this.
  5. hazzmatt89
    64
    56
    Oct 3, 2023
    Thank you, the guy who has it said he did an alignment with tires 7 months ago he has a shop and is a tire seller for semis, and said he serviced the bearings and packed them back up with grease( they have the grease hubs and not oil) on the trailer.
    I’m just hesitant because I just don’t see many older bensons around here. A lot of combos and east aluminums for the most part
    ducnut Thanks this.
  6. hazzmatt89
    64
    56
    Oct 3, 2023
    It’s one of the older bensons not the fontaines, I’m capable of going over it myself not that hard to see if there is a crack anywhere… I was just looking for some feedback on the trailer.
    As far as 10k for a trailer, there’s a bunch on marketplace in that range and some sell for less if people need the money or just want out. It’s my first flatbed and that’s my budget I gave myself. I’ll have my semi truck paid in cash and a trailer. I don’t want any payments
    CAXPT, beastr123 and ducnut Thank this.
  7. CAXPT
    CAXPT Road Train Member
    3,379
    15,795
    Feb 10, 2008
    The question becomes, how good are you at wrenching, welding, fabricating and repairs in general? Even if the trailer is as good as he says, you should still take that with a grain of salt, if you haven't seen/done it yourself. The point being, you'll need to do the work yourself, or have a budget bigger than your initial outlay. If the option is to keep using the Transcraft until you build that budget up, it might be the better option, but if it's that good of a deal to you to pass up, then make sure you increase the maintenance fund beyond that $2,000 that you'll have left after the purchase for repairs, parts, tools to do it yourself, etc.
    I don't know squat, but I know that would be my plan, should I venture into the O/O area. I like your plan, and it's the way I'd plan to do it, too, but I'm familiar with what I can and can't do, and I'd have to budget according to my abilities.
  8. Iamoverit
    2,159
    4,956
    Oct 31, 2023
    Sorry, I missed that you had Benson in your post title. Anyway, those Bensons have been run into the ground by newbs and a mega that oy cared about maximum profit. I'm confident it's cracked somewhere and/or the axle tubes are thin.
    He probably found one or both of those issues when he tried to align it. You belly load that trailer and it cracks in half and kills someone your business will be over before it even starts. Unless you know exactly what to look for and where to look you'll never find any cracks if the seller hid them by filling them with epoxy or covering with dirt or paint.
    It's your money but keep in mind you share the road with humans and you're legally responsible for their safety.
    CAXPT Thanks this.
