only Marker rear lights not working
Discussion in 'Ask An Owner Operator' started by Transportacion R&R, Jun 4, 2020.
  1. Transportacion R&R
    Transportacion R&R Light Load Member
    175
    73
    Apr 10, 2020
    Only the rear marker lights are not working on the trailer. I hooked up to another trailer and the same issue, therefore im guessing its my truck. I changed out the relay and fuse and still having the issue. I cant expand the pins on the trailer to see if that helps because they are solid pins. Any help would be appreciated, thanks
    All my lights on the truck work, all other lights on the trailer work.
    Trucker61016 Thanks this.
  3. JerzyG
    JerzyG Light Load Member
    93
    265
    May 23, 2020
    You might have a bad pigtail or 7 way socket on the truck. I would try and swap the electrical cord with someone. If that's not it, I'm guessing it's the socket on the truck.
    chevyryder86 and ChevyCam Thank this.
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    The female socket on back of the truck picks up alot of salt and dirt over winter time, truck parts stores sell a pigtail cleaner tool to clean pins you can use on truck and trailer plug in socket?
    feldsforever Thanks this.
  5. Transportacion R&R
    175
    73
    Apr 10, 2020
    I will definitely give it a try to replace the green pigtail. Thats the only thing i can think off that could be wrong.
  6. Transportacion R&R
    175
    73
    Apr 10, 2020
    I tried a different pigtail, same result. Just the market side lights and rear market lights won’t come on. Checked the socket as beat as I could, will try cleaning as best as possible when I deliver load. Could it be a ground fault and where can I look for a ground fault on the truck?? Thanks again in advance
  7. abyliks
    abyliks Road Train Member
    4,121
    9,711
    May 2, 2010
    ludlow MA
    What kind of truck? Some have an extra switch/plug for upper marker lights it might be a different circuit then marker
    Crude Truckin' Thanks this.
  8. JerzyG
    93
    265
    May 23, 2020
    I'm guessing it's the socket on the truck. You can try seeing if you power to the pin where the black cable goes into. If you look a 7 way diagram for trucks/trailers you will see what I am talking about.
  9. AModelCat
    164,678
    Marker or tail lights not working? They're 2 different circuits. IIRC brown wire is tail lights, black wire is clearance lights.
  10. Transportacion R&R
    175
    73
    Apr 10, 2020
    2015 Freightliner cascadia 125 DD13
  11. Transportacion R&R
    175
    73
    Apr 10, 2020
    Agreed, as soon as i park the truck im going to test the socket on the truck. Take out the green pigtail off the truck and test the socket pins. Thats my guess as well, are the sickets pretty easy to replace, this will be a first for me on that one. I imagine a few screws and alot of pictures to make sure i return the wires correctly to the new socket. Hoping its just a lose wire on that socket.
