Opti idle, does it keep you cool when trying to sleep?
Discussion in 'Crete' started by fuel463, Aug 29, 2021.
  1. fuel463
    fuel463 Light Load Member
    63
    52
    Feb 17, 2019
    What is the opinion of opti idle? I have never used it and was curious if it will keep you cool when you are trying to get some sleep
  3. MiFamilyGuy
    MiFamilyGuy Light Load Member
    199
    295
    Sep 17, 2012
    What I've heard from a friend that has it is you'll want to shut down later in the evening if you're schedule allows, and start your break with the truck as cold as you can get it. He says it's not great on hot summer nights but he prefers it to the headaches he had with the APU on his previous truck.
    fuel463 Thanks this.
  4. 48Packard
    48Packard Ol' Two-stop Shag!
    8,464
    10,324
    Apr 19, 2009
    Could be anywhere
    I’ll take my diesel powered APU any day over Opti-Crapple.
    Wasted Thyme, Rocks and Speed_Drums Thank this.
  5. flood
    flood Road Train Member
    4,169
    4,051
    Dec 25, 2010
    I'll stick with my gas generator and portable ac
    Speed_Drums Thanks this.
  6. nredfor88
    nredfor88 Road Train Member
    1,801
    6,105
    Sep 26, 2019
    USA
    I'm in my second opti-idle Cascadia, matched with a bunk heater. It works great. No issues in the summer with AC, in fact most of the time it is too cold. I end up having to put it on the lowest settings and block and redirect some of the vents, even in 100 degree weather. In cooler weather that requires less cooling, it will start and shutdown the engine periodically. I've never had and issue. In the winters, it will always make sure the battery is charged by starting up the engine when necessary due to engine temperature or if the batteries need a charge.
    I love opti-idle.
  7. Phantom Trucker
    Phantom Trucker Medium Load Member
    382
    685
    Jan 11, 2016
    Calgary, AB
    I was parked beside a CRST truck one night. It had that opti idle on it. The truck fired up on its own about twice every hour and ran for maybe 10 minutes.
    How’s a driver suppose to get a good night’s sleep with that? (Truck shaking every time it shuts down, probably beeping when it starts up).
    Opus, Rocks and Speed_Drums Thank this.
  8. nredfor88
    1,801
    6,105
    Sep 26, 2019
    USA
    It takes a couple nights to get used to, then you don't notice.
    Rocks, flood, BigBob410 and 1 other person Thank this.
  9. Last Call
    Last Call Road Train Member
    7,568
    45,914
    Mar 15, 2021
    Seriously ????
    Does your mommy facetime you every night and tell you a bedtime story then sing you to sleep ??
    Your a truck driver suck it up butter cup
  10. BigBob410
    BigBob410 Road Train Member
    5,665
    74,101
    Feb 2, 2016
    Beirut on the Bay, MD.
    My Mom calls every night and tells me a bed time story.....I don’t see the issue here.o_O I’m tough but you only get one Momma!
    Opus, Rocks, motocross25 and 1 other person Thank this.
  11. Phantom Trucker
    382
    685
    Jan 11, 2016
    Calgary, AB
    How does that question get you all worked up like this?
    Vision, Opus, Rocks and 4 others Thank this.
