OSOW Turn By Turn Help!
Discussion in 'Heavy Haul Trucking Forum' started by alex.sweitzer, Mar 4, 2024.
  1. alex.sweitzer
    alex.sweitzer Bobtail Member
    Mar 4, 2024
    Hey everyone,
    Does anyone have any insight into a software that would remotely route drivers based on permits? The way we currently do it is I receive all of the permits and then modify the route on google maps, print it out, and give a paper turn-by-turn to the driver. This is fine but when you're trying to read through a piece of paper while on the road its a bit precarious.
    I have tried using the Garmin Dezl units and using Garmin's Trip Planner Software but I dont think its been updated since the 90s and you physically have to plug the unit into the computer that you are making the trip on. Co-Pilot seems to require entering stops as opposed to Via Points which is not ideal.
    Basically what Im looking for is some system where I can punch in a trip on a laptop/desktop/tablet/etc... modify it to match the load's permits, and send it to a truck-based GPS unit where the driver can pull up that trip and receive turn-by-turn based on the route shaping provided. We do a lot of over-the-road into unfamiliar places so knowing exactly where a turn is coming up would be very helpful.
    A couple of years ago, I spoke with the development team at Garmin who told me that they were working on something like this but I never saw/heard anything further.
    I figured by 2024, a company would have designed a software that is capable of this, but so far I've had no luck finding anything that works quite right. If anyone has similar concerns or has any leads please let me know! Thank you.
    Alex Sweitzer
    C&C Ventures, LLC
    Marine Transport
    W923 Thanks this.
  3. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,013
    2,085
    Dec 15, 2021
    Hammer app has OS,you have to enter the truck dimensions.But I don't know if the route it determines would be the same as your permits.
    alex.sweitzer Thanks this.
  4. alex.sweitzer
    Mar 4, 2024
    Yeah that seems to be the other issue I've had with different truck routing apps. They will route you on a way that their software seems fit but not necessarily what your permits say.
    W923 Thanks this.
  5. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    If you cant trust your drivers to follow their permitted route without step by step instructions from you, they dont belong in the drivers seat of an os/ow load.
  6. Hayfieldmn
    Hayfieldmn Light Load Member
    158
    239
    Sep 10, 2016
    Just tell them to take the longest, dumbest route from A to B and it will match the state routing 95% of the time.
    cke and Oxbow Thank this.
  7. kylefitzy
    kylefitzy Road Train Member
    4,752
    19,799
    Aug 12, 2007
    Kansas city,Mo
    Hiring drivers that need this level of hand holding is what’s wrong with trucking. I use a Dezl and it works just fine putting in the route by hand.
    cke, Oxbow, beastr123 and 3 others Thank this.
  8. Landincoldfire
    Landincoldfire Heavy Load Member
    927
    5,115
    Sep 27, 2015
    New Holland, Pa
    Enroute for Apple works well and you are able to share the route. I won’t say anything about the skill level of your team because it has already been addressed.
    cke, Oxbow and beastr123 Thank this.
  9. tarmadilo
    tarmadilo Road Train Member
    1,731
    4,771
    Dec 12, 2018
    I assume that you adjust the route on Google Maps to fit your requirements, with each adjustment shown by a pin or flag, right? Give your drivers a list of those pin locations so they can set up the route on Google Maps in their devices, keeping the paper version from you as a backup.
    James j Thanks this.
  10. fisher guy
    fisher guy Road Train Member
    1,993
    1,061
    Mar 22, 2009
    Ocala Florida
    seems to be an old thread but if your still looking i highly recommend INROUTE for IOS. I've been using it for a couple of years and all my pilot escorts use it. plot the route from your permit and it will stick to it and give you turn by turn directions like google maps. just make sure you put the points on the right side of the road
