Outlets Out
Discussion in 'CFI' started by Melika0829, Apr 26, 2025.
  1. Melika0829
    Melika0829 Bobtail Member
    10
    4
    Sep 28, 2020
    Phoenix
    Started here over 1 yr ago. 3 months in, my inverter was finicky. Joplin said it was all good. Went to Heartland in PA. He tested all my batteries, all junk replaced. Still inverter problems. Heartland Phoenix replaced my inverter..3 days ago, it went out. Alvarado replaced it. The power control in the bunk is on, the inverter is on, ALL MY OUTLETS ARE OUT IN MY BUNK AND I CANT COOK ANYTHING!!! I know there are 3 fuse boxes, but which/what fuse is SPECIFICALLY for my outlets? PLEASE HELP! IM HUNGRY!!!
    JOHNQPUBLIC and tscottme Thank this.
  3. tscottme
    tscottme Road Train Member
    The power outlets on inverters are usually GFI outlets. So they can "pop" but it's not obvious. Look for a reset and a test button on or near the power outlets on the inverter. Press the Test button, which will make them "pop" and then press the Reset button, which should make them work again. Also look for a round circuit breaker on the inverter and see if it popped. If so press it in to reset it.
    D.Tibbitt and Melika0829 Thank this.
  4. Melika0829
    10
    4
    Sep 28, 2020
    Phoenix
    I think I'm going to have to get it fixed in Joplin, or when I go on home time in 2 weeks....I don't see a reset...
    tscottme Thanks this.
  5. tscottme
    I don't see a reset, circuit breaker, and the only fuse may be in the gray housing near the yellow plug. Run your hand around all sides, feeling for any switches or circuit breakers. If there are none, the shop or the inverter manual needs to be consulted.
  6. Knightcrawler
    Knightcrawler Road Train Member
    1,766
    6,913
    Apr 10, 2017
    Mpls, Mn oops Ocala, Fl.
    Too bad truckstops dont offer incentives like credits for gassing up that you could use to buy stuff from there. You know, like FOOD.
    Pity.
    Moosetek13 Thanks this.
  7. Moosetek13
    Moosetek13 Road Train Member
    14,966
    19,000
    Nov 1, 2010
    Burnsville, MN
    Or just using some cash from the paycheck to buy some food.
